'88 4Runner w/Fast Idle
Old Dec 26, 2009 | 06:48 PM
JBHoren's Avatar
Question '88 4Runner w/Fast Idle
About two weeks ago, the idle on my 1988 4Runner (22-RE) suddenly jumped way the hell up... really racing... it'll do 20mph in second gear, with my foot off the gas. I tried backing off the idle with the adjustment screw, but that only made it rough, not slower. I've noticed that when I press the clutch pedal, the revs go way up; but, even when it's in gear, it idles much higher than it should. It's not temperature-dependent: the same behavior occurs at -20*F and at 20*F (and we've had both extremes within the past two weeks). Any ideas? Cures? Suggestions?
Old Dec 26, 2009 | 08:05 PM
myyota's Avatar
Pull the throttle body and give it a good cleaning and also check the TPS and make sure its properly adjusted.
Old Dec 26, 2009 | 08:06 PM
davo247d's Avatar
how do uy ajust the tps?
Old Dec 26, 2009 | 09:30 PM
myyota's Avatar
Check out www.4crawler.com he explains how to do it.
Old Dec 27, 2009 | 06:38 AM
4Crawler's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Dec 27, 2009 | 06:10 PM
JBHoren's Avatar
Guys: thanks for the info! Now, if only I had somewhere to work on it, that wasn't outdoors and at below-zero temperatures :-(
Old Jan 13, 2010 | 07:18 AM
gburnett's Avatar
mine is injected but it did the exact same thing, however my problem was the guide for the throttle cable was bent shut with the cable sitting on top therefore it revved much higher that it shouldhave
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
