Wont start goin crazy!!!
Old Jan 12, 2010 | 02:16 PM
dustins's Avatar
85 p/u 22re,Ok truck won't start, thought I was frozen up for a min. but I got fuel everywhere, It will crank fire up for about 3-5 seconds and die. Did get it goin the other day adn took off down the road real quick. It spit and sputtered and the just took off and was fine all day until the next morning. My CEL is on but I dont have a clue how to pull codes on this truck. Not like my 91 with the te1 and e1 port. Anyone have any Ideas??
Old Jan 12, 2010 | 02:56 PM
wrnchplr's Avatar
on the drivers side inner fender there are 2 yellow pig tails. one bigger then the other. cant remember what one but jump it like you would a 91. do a search, I know the info is here.
Old Jan 12, 2010 | 03:28 PM
Travisfab's Avatar
Change your fuel filter.
Old Jan 12, 2010 | 03:34 PM
dustins's Avatar
Ok I know which is the diag. plug cant pull a code tho just gettin a solid engine light it only ever comes on after 2,ooo rpm think it's the oil press. gauge. It dont work. What about fuel pump is there a way to test it, thought I heard of a plug like the diagostic one to test it.
Old Jan 12, 2010 | 04:08 PM
wrnchplr's Avatar
on the OBD1 if the light comes on it will store the code. as far as the oil pressure gauge not sure what your talking about there. there isn't any way to test the fuel pressure, but the pump you can hear turn on or crack the line going to the cold start injector and see if gas sprays out.
Old Jan 12, 2010 | 04:24 PM
1990yota-pickup's Avatar
take off the fuel return line from the fuel rail and trying a rank the enging.. just have some one hold the line into a small bucket and have some else crank over the engine and see if there is any consant flow of fuel coming out...
you may have a bad fuel regulator, it wont hur to change your fuel filter..
make sure you actually have gas in the tank.. ( give the tank a knock or two for hollow sound to see if its empty..)
you can also crack the line to the fuel rail from fuel filter.. and crank engine it its spraying good you know your getting good pressure..
check the manual of actual psi
pick up a fuel pressure gauge from harbor frieght tools should be under 15 bucks for a whole kit.. (NEVER HAD PROBLEM WITH MINE)
CHECK the manual for trouble shooting procedures..
Old Jan 12, 2010 | 04:31 PM
wrnchplr's Avatar
I don't suggest cracking the line at the fuel filter on a 22re. the gas leaks out right on the starter, easy was to start a carBque...
on the 22re I wasn't awear that there was a tool to check the fuel PSI as there is no in-line place to check it. could you please provide a link to said tool? I would like to get one.
Old Jan 14, 2010 | 06:47 AM
dustins's Avatar
Well changed filter and no luck same story . Also the pump is kickin I can turn the key to on and flip the maf door thing and hear it humming, sooooo, yea I dont know. Runs for a couple secs and shuts er off.
Old Jan 14, 2010 | 08:20 AM
dustins's Avatar
Jumped fuel pump heard it run but no change
Old Jan 14, 2010 | 09:53 AM
dustins's Avatar
Captain moron here fixed it. What seemed like a fuel problem with all the symptoms of it was actually three wires running atop the from the coil, they were laid down on the manifold and were bare and touching. It's perfectly fine now and eh it's got a new fuel filter.
Old Jan 14, 2010 | 10:44 AM
wrnchplr's Avatar
you got it running on your own, good job
Old Jan 14, 2010 | 11:03 AM
dustins's Avatar
Thanks people, by the way YOTA TECH RULES!!!!
Old Jan 14, 2010 | 12:24 PM
how about that.. it you want to get a cheap fuel pressure tester go to harbor frieght tools
Old Jun 19, 2011 | 02:08 PM
HighwallGrant's Avatar
also have crank but wont start problems, 1990 22re pickup, just had timing assembly installed new, new ecu, new fuel pump, new fuel filter, new fuel rail, got fuel pressure to the fuel rail and pulse through the harness to the injectors, got fire to spark plugs, but no fuel into the cylinders, tryed another set of injectors (used) still no change....... about to go nuts plz help
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
