The problem im having is spark timing
Old Mar 11, 2014 | 05:39 PM
Arnieg727's Avatar
The distributer is maxed out it still needs 5 degrees.... I think
It's a 22re out of an sr5. Timing seems to be a hair off. Just a hair. Or is there any other things I should check??
I'm a noob and don't have a whole lot of time under the hood but am trying to learn and try to figure out problems on my own
Thanks anything will help
Also lack of power while under load (in drive or reverse) (couldn't role through thick sod hah)
Old Mar 11, 2014 | 05:45 PM
JasonYota's Avatar
The distributor could be off a tooth. Never messed with one on a 22re though, others may chime in some info
Old Mar 11, 2014 | 05:48 PM
Arnieg727's Avatar
I've turned it a tooth and the rotor was not facing cylinder head one after I lined up the timing
Inferno451's Avatar
How are you measuring the timing?
Old Mar 11, 2014 | 05:56 PM
Arnieg727's Avatar
Timing light?
Old Mar 12, 2014 | 04:52 AM
JasonYota's Avatar
Originally Posted by Arnieg727
Timing light?
lol I think he meant what kind
Old Mar 17, 2014 | 03:46 PM
Arnieg727's Avatar
Thanks for the in put I turned my distributer a full tooth and i have power but my timing is a little advanced but she runs good
voiddweller
19
May 2, 2016 09:10 PM
marcusSRG
Jun 27, 2015 07:13 AM
torgeir
Jun 25, 2015 05:26 AM
saphirekosmos
Jun 22, 2015 10:26 AM
Mohamed
17
Aug 21, 2002 12:54 PM
