Ways of lifting my yota
Old Feb 19, 2014 | 05:06 PM
Arnieg727's Avatar
I have a 85 pick up with a 6inch leaf spring lift. I'm looking for a way to add another 3 or 4 inches with out using blocks or a body lift. I have blocks in the rear now, but would like to eliminate blocks all together. Any recommendations? Cheaper the better!
Ive heard of people using Chevy leafs but idk if that's true or not?? I wanna clear 40s with put trimming body
Thanks, anything helps
Old Feb 19, 2014 | 05:33 PM
The Tick's Avatar
There is no good or cheap way to get 10 inches of lift. Also, driving with 40's will suck with stock gears. You're going to need 5.29 gears and dual t-cases or low low t-case gears. Good luck, and hope you find something!
Old Feb 20, 2014 | 03:10 PM
Arnieg727's Avatar
We'll I don't really need 40s could I run 35 or a 37? And not need to re gear??
Old Feb 20, 2014 | 03:18 PM
The Tick's Avatar
I would still definitely recommend regearing, but you don't Have to, just know that with anything bigger than 33's it will be pretty much unusable on the road, but it will be somewhat acceptable on the trails....just go for the 5 in. springs to get a 6 inch lift.
Old Feb 20, 2014 | 03:28 PM
Arnieg727's Avatar
Thanks man
Old Feb 20, 2014 | 03:35 PM
The Tick's Avatar
Yep, no problem. That should clear 37's with only very minimal body chopping if any, but again, they aren't cheap.
Old Feb 20, 2014 | 05:17 PM
Stetson_md's Avatar
10" of lift? Do a ruf and ford or chevy swap and use lift springs instead of stock springs.and Or use drop hangers and shackles. Full size axles would be a good idea to
If I remember right regular ruf and chevy/ford swap gets you about 4"so use a 6" lift spring and that should put you near where you want.( research it don't go off my memory my memory blows)
Old Mar 17, 2014 | 03:48 PM
Arnieg727's Avatar
Ended up just doing a shackel lift but thanks for the input
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
akaphilly
Jul 9, 2015 02:18 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Vargntucson
Jul 4, 2015 12:15 PM
