What's this part called?
Old May 12, 2014 | 04:49 AM
87xcabsas's Avatar
This vacuum line part melted and I'm lost trying to find part number or name.
Old May 12, 2014 | 05:06 AM
JasonYota's Avatar
What year? Engine? Where is it located on the engine? That will help
Old May 12, 2014 | 07:47 AM
4Crawler's Avatar
Was that screwed into the power steering pump? If so, that is the air valve for the power steering idle-up. I've not run one of those for 10+ years and don't really miss if, just screw it back into the pump (to seal it up) and block off the vacuum lines:
- http://www.4crawler.com/4x4/CheapTri...ine_Pix/7.html
All that part does is bump up the idle speed when the p/s pump pressure goes high, like when you are cranking the steering wheel over at a stop. I find most of the time that is not needed and if it is, I can blip the gas pedal if the steering is too heavy.
Old May 12, 2014 | 08:56 AM
87xcabsas's Avatar
It is a gas filter located on the side of the intake of a 22re. Dealership sells them for $32. I ended up sealing up the bad spots and re opening on of the spouts for the vacuum hose to slide on and it worked perfect. Fired up and purred like a kitten
Old May 13, 2014 | 11:13 AM
okamikai's Avatar
It seems like a pressure switch of some sort, where was it attached to?
smthwsn357
May 1, 2024 07:28 AM
Iceman4193
Jul 15, 2015 04:48 PM
Steven.m.paulk
Jul 13, 2015 01:40 PM
AaronM
Jul 8, 2015 07:15 PM
