weber carb 1 piece adapter help
Old Jan 26, 2014 | 12:20 PM
mikeyd6789's Avatar
So I've bolted on my weber carb, everything fits good except for my throttle linkage. Being that I used a one piece adapter plate that is a lot thicker than what came with the weber (thinner 2 piece) the throttle linkage is not lining up with my carb now....what do I do?
Old Jan 26, 2014 | 12:53 PM
dropzone's Avatar
Fossilized
Improvise, adapt and overcome.
Look for places along the mounting area of the throttle cable where you can adjust it up.
You might need to make a small extension bracket. Why use a taller plate?
Old Jan 26, 2014 | 01:11 PM
mikeyd6789's Avatar
I dont excactly know why its so think... That's the one everyone recommend me to get. From summit racing. Maybe I can figure out how to rig a spacer up.
Old Jan 27, 2014 | 06:27 PM
JonnyBoy's Avatar
Basically that's it. The kit to install it on a 22r should come with spacers for the throttle linkage too. If the carb spacer is taller, you need to move the linkage up pretty much the height of the spacer. Probably need new longer bolts, too.
4.34runner88
Feb 7, 2016 02:24 AM
user 82300
Jan 19, 2016 02:01 PM
bhaithc
Sep 17, 2015 07:53 PM
icentropy
Sep 10, 2015 05:03 AM
