Smog Legal headers
Old 01-25-2014, 03:51 PM
RTFK's Avatar
Smog Legal headers
hey guys im looking for some California street legal headers fit with the air injection bung anyone have any tips? thanks 1984 pickup SR5 with 22r
Old 01-25-2014, 06:22 PM
herpestes's Avatar
check LCE
but.........kind of pricey
Old 01-27-2014, 07:21 AM
highonpottery's Avatar
LCD, thorley, trail gear, Stan's headers, etc. I'm more of a fan of tri-y header like the stock exhaust layout over the 4 into 1 like LCE and others make.
Old 01-27-2014, 07:26 AM
MaK92-4RnR's Avatar
^^^ what he said.
Old 02-07-2014, 09:07 PM
hitsua's Avatar
I know the Trail Gear header specifically can be used with air injection, and it also comes with a blockoffs incase you are fuel injected. I just smogged mine a few days ago with one on it.
Old 02-07-2014, 11:19 PM
Old_ blue's Avatar
depends if you get it smogged every 2 years. so it depends on the local laws. if the laws have it so that you get it smogged once and done after that who cares what you get. just search. if you try and get around to smog it and an unexperienced smog tech you could proly get an aftermarket header by them.
Old 02-27-2014, 10:35 AM
SqWADoosh's Avatar
Having just invested in some new headers I'll tell you my experience. I went with Doug Thorley after some people in my build thread recommended them. The headers fit great on the manifold side however they have caused a change of angle on the CAT side where I now have to invest an additional $200 on getting a custom exhaust from the CAT back. If I had to do it all over again I probably would have gone with LCE. From what I hear they fit perfectly without having all the hassles I'm having. I've been running open headers since Saturday because all my local muffler guys are booked until tomorrow. Needless to say my neighbors aren't my biggest fans right now
The following users liked this post:
Mwhite49 (11-26-2019)
Old 11-11-2019, 05:59 AM
Andrew Parker's Avatar
Doug Thorley Header Joint Modification
It is safe to proclaim that for California the DT header is the only brand that has a smog compliant CARB number. But the slip joints and u-clamps leak and will through your O2 sensor off. So welding turbo flanges to the headers and pipes that use a tapered clamp band has done the trick. My 91 passed it's by-annual with a 2-1/2 Magnaflow CAT again using the same flange to join it to the header's y collector. While sorting the header I was using a new NTK O2 sensor which proved to be DOA. The tell tail was awful throttle response once it was warmed up and running closed loop. So I am unsure how critical the leaky joints might be and what is more DT did get the CARB exemption with the product as designed.
Just did a run to Gold Mountain in Big Bear on Saturday and got 16 MPG and 211 miles out of the tank full. This is the best mileage yet and the 100 miles to the trail head was up to 7,000 ft and mostly 70-75 MPH for the freeway portion. OEM gearing with 31's, BJ-spacers up front and Daystar spacers at the rear for an increased frontal area. K&N cold air intake with custom made airbox enclosure that is integrated with the OEM shroud that is behind the head lamp. Running 16 inch long muffler in place of CAT with restrictive Bosal OEM Cat back behind this. It has a great sound to it.
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
dbollier123
09-29-2015 05:23 PM
myotherrideisayoshi
09-29-2015 05:41 AM
charlie_fong
09-27-2015 10:06 PM
taraf
09-25-2015 02:57 PM
Quick Reply: Smog Legal headers
