noise in 4x4
Old Apr 6, 2014 | 02:04 PM
mikeyd6789's Avatar
noise in 4x4
At about half to full turn in 4x4 I have a hard clicking noise in or near my front hubs/knuckle area. Brakes actually locked up in front shortly after. Not sure if the brakes are an unrelated issue or not. Pressed brakes a new times and they let go. I know I'm in desperate need of a knuckle/axle rebuild, but what is causing this hard clicking? Almost binding sound?
Old Apr 6, 2014 | 03:52 PM
mikeyd6789's Avatar
Will also say I'm not doing this on hard pavement. Also does it on wet grass and mud.
Old Apr 6, 2014 | 04:42 PM
mikeyd6789's Avatar
Alright...no responses yet lol....but I'm pretty sure its the CV axles...now leads me to my next question...would CVs cause it to only click in 4x4? And will it hurt the t case or any other components to run a bad CV for a while? Tapped out at the moment.
Old Apr 6, 2014 | 06:11 PM
dropzone's Avatar
Fossilized
It is a spring day on a weekend..give it some time, YT folks are pretty good about chiming in
To start trouble shooting I would put the truck up on all fours (jackstands) and start turning the front wheels with both hubs locked than unlocked. Give them a few turns both ways..Might be a busted hub ring, bearings or maybe a blown birf..
If it is an 84 you have birfields (technically a CV) but not in the tradition toyota way..As in IFS CV..
Old Apr 7, 2014 | 12:48 PM
mikeyd6789's Avatar
Haha I was trying to be sarcastic...I had posted 3 times in an hour. Figured someone was gonna flame me lol. Will try that when it stops raining! Thanks for the help!
Old Apr 9, 2014 | 09:43 AM
mikeyd6789's Avatar
Alright I'm about to order marlin axle rebuild kit...and I'm wondering if I should get 2 of there birfields too....called (marfields). I'm pretty sure I have a bad birf. Only get a clicking when locked in 4x4 and turning. Nothing at all in 2 wheel. Any recommendations?
Old Apr 9, 2014 | 05:20 PM
rokblok's Avatar
Longfields are good too. Not the Trail-Gear Longfields, but actual Longfields, if someone can post who carries them. I'm not sure if RCV carries a joint for the solid-axle. But if they do, they're strong too. I'm not certain on the actual Marfields compared to Longfields. Do a Google comparison search.
Old Apr 9, 2014 | 05:27 PM
mikeyd6789's Avatar
Alright will do...thanks. Something else I'm lost on...what spline count should I get?...I've seen lots of numbers.
Old Apr 9, 2014 | 05:46 PM
rattlewagon's Avatar
27 is stock. you can also buy chromo 27 splines, and 30 splines are the best. I think stock has a break strength of 4600lbs, chromo 27s are mid 7000 and the 30s are upper 8. You can get actual numbers from the web, thats just of the top of my head.
What you need depends on how hard on your truck you are.
All solid axle shafts (stock, and 30s) are both 30 spline at the diff and the hubs, when they say 27 or 30, they are talking about splines where the axle shaft goes into the birfield.
Old Apr 9, 2014 | 05:58 PM
mikeyd6789's Avatar
Thanks for clearing that up!
Old Apr 10, 2014 | 10:58 AM
mikeyd6789's Avatar
So i can get 30 spline, with my stock inner axle? I dont have to go with 27s?
Old Apr 10, 2014 | 11:09 AM
mikeyd6789's Avatar
Nvm I got it...have to be 27s unless I change out inner axle. Duhh. I'm not gonna be crawling at all...some mud and logging roads here and there. To my understanding...trail gear bought bobby longs rights to the longfield super axles. So I'm gonna go with them I suppose (27 chromo).
Old Apr 10, 2014 | 11:12 AM
To use your stock inner axle, you will need 27 spline. When you buy a "30 spline kit" it comes with new inner axles and birfs that are BOTH 30 spline where the inner axle goes into the birf.
Originally Posted by tyes
S
Stock/27 spline
30 (hub)--------27----27-------30(diff)
30 splines
30(hub)---------30----30-------30 (diff)
Heres some good ole fashoned tech: http://www.pirate4x4.com/forum/toyot...e-results.html
Originally Posted by desertoy
Longfield 4340 30 spline (shaft failure)......................8,500............... ......175
Longfield 4340 27 spline........................................6,50 0.....................75
Stock Toyota Birfield.......................................... ..4,200 .....................45
Stock Toyota Inner Axle.......................................5,000 .....................45
So you can see putting 27 splines on a stock axle will move the weak point to the inner axle shaft.
Old Apr 10, 2014 | 11:16 AM
mikeyd6789's Avatar
Awesome info man! Thanks a lot. All new to me!
Old Apr 10, 2014 | 11:19 AM
Happy to help!
RCV made the old longs... and used to make the dirty 30s.
You can get rcv shafts (aka the real longs) from Davez off road. Can still get the IFS conversion hub gears too.
http://www.davezoffroadperformance.c...eld-axles.html
Old Jun 17, 2014 | 03:24 PM
StayFoolish22's Avatar
Still the best?
So after reading through this thread and a few others, is the set of original longfields from davez the best you can get? Reading through the report from 2006-2008 they look pretty high up there in terms of taking abuse. Looking to replace on an 84 ext.
Old Jun 18, 2014 | 03:10 PM
osv's Avatar
osv
some people can bend a crowbar in a sandbox... it kinda depends on what you are doing.
can't go wrong with longs(aka rcv) from davez, most people think that they are the best.
the dirty30s, or whatever tg is doing, is probably plenty strong, and has traditionally been cheaper than longs.
i would not run the marfields, unless your truck is light, with a 22re, and you aren't going to be hammering it with the heavy pedal.
whatever you do, remember that you'll probably have to get matching hub gears, or it'll void the warranty, if that's where the breakage is.
mskalmus
May 28, 2017 07:51 AM
coleypull15
Nov 3, 2015 07:41 AM
PlayAwhile
Jul 20, 2015 11:36 AM
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
