Caster, camber adjustments on 86 pickup
Old 12-10-2015, 01:32 AM
Yotafan23's Avatar
I need a little help, I've got an 86 Toyota pickup and the front is out of alignment, The caster on the right front is at least 2.1 degrees off of where it needs to be and I can't adjust my eccentric cams any farther. My ball joints seem to still be fine and my control arms still look good (they haven't been bent or hit at all) but try as I might, I can't get those last two degrees of adjustment. Is there anything I can try? Also can the top control arm be adjusted at all? Thanks.
4x4YOTA
08-23-2016 09:08 AM
deerleasetruck
11-02-2015 03:13 PM
83
11
10-19-2015 04:57 AM
BIGDEERHUNTER
10-06-2015 03:09 PM
crash813
09-27-2015 07:15 AM
Quick Reply: Caster, camber adjustments on 86 pickup
