Is there a way to ID a year on 8" diff?
Old Feb 5, 2016 | 08:27 PM
bsnake96's Avatar
My truck has had front and rear end replaced a long time ago. Swapping over to another frame, and would like to ID these diffs a little better. My question is, is there a way to it narrowed down to a year? They have 4.38 Gears, which from what I understand were only a factory option in 1980. However, I can't rule out that they could be aftermarket R&P. They are both 8" solid, only markings on ring gear are "35X8" and only 3 digits on the webs of the 3rd member. "24E" or "2AE" do those mean anything?
Old Feb 6, 2016 | 05:37 AM
MudHippy's Avatar
Short answer = No
Why does it matter?
Old Feb 6, 2016 | 11:17 AM
bsnake96's Avatar
Originally Posted by MudHippy
Short answer = No
Why does it matter?
Would just like to know what I've got. are all 79-85 parts interchangable? Brake,s bearings, seals, gears etc.
Old Feb 7, 2016 | 05:38 AM
MudHippy's Avatar
The gears would be. But the pre-84 pinion flange has smaller bolt holes(8mm vs. 10mm). The rest I don't know for sure...at the moment.
Old Feb 7, 2016 | 02:44 PM
bsnake96's Avatar
Alright thanks man. If you find out anything else please let me know. I've been doing some part number interchanges and so far only wheel cylinders and rotors are different throughout 79-85. So maybe that will help something. So did you mean 8mm heads, or M8 bolts at pinion flange? Wasn't aware of that but that should be helpful!
Old Feb 7, 2016 | 03:08 PM
MudHippy's Avatar
M8 bolts 79-83
M10 bolts 84-95 4 cyl.(or 7.5" diff)
M11 bolts 85-95 Turbo/V6
Old Feb 7, 2016 | 03:10 PM
bsnake96's Avatar
M8 bolts 79-83
Cool thanks
mtb_taco
Jan 19, 2016 12:18 PM
88yota22re4x4
Dec 4, 2015 10:39 PM
leviathan278
Nov 30, 2015 08:45 AM
Mms1361
Nov 21, 2015 02:51 PM
Steven.m.paulk
Nov 13, 2015 08:57 PM
