SR5 gauge problems
Old Feb 23, 2016 | 07:42 AM
Rosco1977's Avatar
SR5 gauge problems
I put an SR5 cluster in my 85 4runner
Volt and fuel gauge work GREAT so far
Oil and temp have the problems
Oil excites to the bottom of the line and the temp starts in the center. I have replaced the sending unit on the oil presser on the block (AKA the big one)
and have cleaned the off the temp unit on top of the water neck on the EFI!!
any other ideas would be great!!! Thanks
Old Feb 28, 2016 | 12:28 PM
1985 4Runner's Avatar
Did you unplug the oil pressure sender prior to hooking everything up?
Old Feb 29, 2016 | 10:12 AM
Rosco1977's Avatar
yes i did even bought a new one
Old Mar 3, 2016 | 06:42 AM
se7enine's Avatar
Does the oil gauge move when you accelerate? As far as temp is concerned it could be the voltage from the sender is too high. Did you test the gauge per FSM?
Old Mar 3, 2016 | 11:11 AM
Rosco1977's Avatar
The oil pressure needle moves to about the low line when accelerating
Old Mar 3, 2016 | 11:47 AM
se7enine's Avatar
Thats how all my 1st gen 4Runners would act too, not sure if I would call it normal but I've heard it is for most. Mine would never read halfway.
Old Apr 18, 2016 | 05:46 PM
reelal's Avatar
Green temp sensor on the water neck is only for the Ecm the temp sensor for the gauge is in the middle of the intake just to the right of the valve cover.
Old Apr 18, 2016 | 06:48 PM
old87yota's Avatar
Not sure about the oil pressure gauge but the coolant temperature gauge is known for problems. Check what they said above^^, along with wiring. The gauge sender and the ECU sender are different.
I do know that both of those gauges share the same board inside the cluster.
For the coolant temperature gauge problem, check out this thread:
https://www.yotatech.com/forums/f116...ge-fix-271152/
I bought an SR-5 Cluster for my truck and have the problem mentioned in this thread, but I haven't gotten around to fixing my cluster yet, so I have no first hand experience to help you.
Good luck!
-Jake
btu44
Oct 7, 2016 08:03 AM
89Hilux
Jan 10, 2016 09:10 AM
SunnyCoastSteve
Dec 17, 2015 06:52 PM
PureTacoma_Tundra
PureTacoma_Tundra
Dec 4, 2015 08:16 AM
4.34runner88
Dec 3, 2015 11:09 AM
