frame plugs
Old Apr 12, 2016 | 03:24 AM
maico45ger's Avatar
frame plugs
Are there any sources for the oval rubber frame plugs? There are five located on each outside section of the frame. I prefer aftermarket ones, if possible.
Thanks
Old Apr 12, 2016 | 08:37 AM
MudHippy's Avatar
Other than Toyota? No. There's some on the inside of the frame too. And they aren't rubber or oval. They're polyethylene and rectangular(a.k.a. a rounded rectangle), with the part number on the other side(that you can't see when installed). 90950-01395
Old Apr 18, 2016 | 05:23 PM
reelal's Avatar
Those plugs are good for keeping water inside the frame but not so much at keeping it out.
Old Apr 18, 2016 | 05:34 PM
MudHippy's Avatar
This is true. They do keep more solid debris out pretty effectively though(mud, small stones, etc.).
Old Apr 26, 2016 | 03:56 AM
maico45ger's Avatar
I am most concerned about the plug holes outside of the frame near the wheels. I clean out the frame with compressed air, then spray inside with a combination of hydraulic oil/bar and chain oil. Then install the plugs. An annual inspection to check on mouse nests etc. is done, then another application of oil.
Old Apr 26, 2016 | 03:57 PM
MudHippy's Avatar
They're painted(powder coated?) inside and out after welding. Not that a little more protection is a bad thing. Just that it won't do you any more good than wiping down the outside with oil.
amites
Jun 30, 2016 02:42 PM
yotajakes
Feb 23, 2016 03:55 PM
