Which wire for aftermarket tach?
Old Sep 21, 2018 | 04:45 PM
BrendaGT's Avatar
5 Year Member
Hey guys - I've read several threads and I'm still not completely clear. I have an aftermarket tach for my 84 22R. All wires are hooked up except the green, which is routed thru my firewall toward the ignition coil and igniter. Should I splice into the black wire that runs between igniter and coil
Black wire between igniter and coil
or, alternatively, there is a plug coming off the igniter which isn't used for anything. Can I plug my green tach wire into this plug using a spade connector?
Where the wire for this plug comes out of igniter
The plug
Looks like spade connector might fit
i prefer the plug if that will work, but anything safe and correct will make me happy Thanks!
Old Sep 21, 2018 | 05:00 PM
Co_94_PU's Avatar
The capped off plug is your tach signal, you got lucky lots of people can't find it.
Old Sep 21, 2018 | 05:20 PM
BrendaGT's Avatar
5 Year Member
Oh sweet! Thanks! It seemed too easy but I guess I'm indeed lucky
neockder
Apr 28, 2012 10:15 PM
southernZ
Jun 19, 2011 03:53 PM
vwfastg60
Nov 5, 2007 11:56 PM
Dailydriver2
Dec 16, 2005 04:12 PM
