What year is my engine?
Old Mar 12, 2018 | 06:09 PM
NYHumpinUtah's Avatar
Hi all,
I have a 84 toyota 4wd pickup that has a 20R in it. The PO changed out the engine at some point and installed a 20R in the place of a 22R which should be in it.
Anyway, I'm trying to figure out what year this 20R is and what is it out of. Is there anyway to find out? There are stamped numbers on the DS of the engine before it says 20R
Old Mar 12, 2018 | 06:42 PM
millball's Avatar
Here's some help.:::::http://www.lcengineering.com/LCTechP...TechNote49.htm
Old Mar 12, 2018 | 07:20 PM
millball
Thanks for the info but not what I'm asking here
I want to know "what year is the engine, I know they were made from 75-80
There has to be a way to tell what exact year it was made and from what it came out of.
Old Mar 12, 2018 | 07:26 PM
millball's Avatar
Originally Posted by NYHumpinUtah
millball
Others have asked about determining engine year and application from engine numbers, but, as far as I know, they have found no database to satisfy them.
If you can find such, I'm sure that it would be of interest to many.
It is irrelevant from a parts id standpoint as the LCE data is more than sufficient to identify compatable components.
Old Mar 12, 2018 | 09:33 PM
Well, I will keep searching for an answer. I would think that the numbers stamped on the engine right before the 20R stamp will reveal the answer. Anyone?
Also, I've been dealing with LCE for awhile now, very good guys over there. Some of there parts say that they are good for certain years say 75-78/9 for the parts and then 78/10 -84 so there must be differences. I'll give them a call, I never did ask them
Old Mar 12, 2018 | 10:23 PM
millball's Avatar
Some of there (LCE) parts say that they are good for certain years say 75-78/9 for the parts and then 78/10 -84 so there must be differences. I'll give them a call, I never did ask them
Well, yeah, that's exactly what the page I gave the link to shows: Specs of 20R blocks and heads, Differences in specs between early 22R blocks and heads versis late 22r blocks and heads.
There is also a 22R turbo block with different specs than other 22R engines. Mostly bungs drilled and tapped for turbo oil feed and drain, I think. This LCE page does not address them.
Old Mar 12, 2018 | 10:27 PM
Co_94_PU's Avatar
To the best of my recollection we have not found any solid production volume information, so knowing your engine number isn't going to give you much..
I suspect the build dates have to do with plug shape changes and that sort of thing, so again not going to be of any use since they (sensors ect..) have been changed to fit the current vehicle.
Old Mar 17, 2018 | 08:31 PM
Made some progress in finding out what year it is. Because there was a change in the water pump design I now know the engine is from 77/10 to 80
Not perfect but closer then i was
Old Mar 18, 2018 | 09:46 AM
Co_94_PU's Avatar
Please elaborate
The more places this sort of information is available the more likely and easier it is to find.
Please elaborate on this water pump change.
Old Mar 18, 2018 | 10:16 AM
It seems that there was a change in the water pump, The early engines from 75 to 8/77 didn't have a center bolt near the pulley, check on LCE web site for a picture of the difference from the early pump to the 9/77 to 80 pump. Mine has the bolt which means the it is the 9/77 to 80 model..
https://www.lceperformance.com/Water-Pumps-s/16771.htm
fatherof4
Aug 28, 2011 06:31 AM
dutchboy
Oct 15, 2008 08:51 PM
