Question about my lift
Old Apr 29, 2018 | 06:23 PM
NYHumpinUtah's Avatar
84 4wd Toyota pickup
Ok, so here's what I have, Old man EMU leaf springs with a 2" lift, Trail gear 5-1/2" shackles front and rear. Now that should give me about a 3" lift. I know the truck doesn't have anything on it but it sure looks a lot higher then that.
First problem, I mounted up the stabilizer bar to the frame and now it's in the way when I go to mount the torque rod. Is there something I'm missing? Is there a riser block for the stabilizer bar that mounts to the frame so the torque rod will clear?
Just some of the 1st problems I'm seeing,
Old May 3, 2018 | 08:33 PM
thefishguy77's Avatar
A picture or 2 would really help.
Old May 3, 2018 | 08:40 PM
https://www.yotatech.com/forums/f198...und-up-304199/
Old May 3, 2018 | 08:45 PM
dropzone's Avatar
Fossilized
I would worry about that when you have the weight of the body/engine on there. You would be surprised how much stuff will settle
I pulled the torque rod on my 84 and my 81, 12 years on the road with both of those with no adverse affects
Old May 3, 2018 | 08:55 PM
Wow, ok so you don't have the torque rod or the sway bars installed? I do have the torque bar installed but not the sway bar. Interesting, thanks
FetusGoulash
Mar 19, 2009 11:43 AM
Justin89
Aug 23, 2008 03:25 PM
ashaskin
9
Mar 16, 2005 01:32 PM
Shane
Jan 8, 2003 10:43 PM
