Interesting Radiator Leak
Old May 5, 2018 | 09:42 AM
bryy's Avatar
So I am looking for some opinion on cause of radiator death.
Backstory:
Radiator is genuine Toyota purchased and installed in 2012
Truck has seen mostly commuting miles the last few years.
Live in Tucson AZ Summers to 115 degrees.
Leaky hose cause upper inch or so of radiator to be empty of coolant for a couple days.(Thinking this is the cause)
The location in on the top of the radiator near the shroud.
Old May 5, 2018 | 11:06 AM
millball's Avatar
Maybe just a weak spot in the tank soldering??
Have you ever changed the coolant since you installed the radiator?
Did you use only distilled water for dilution and make-up??
After a few years the corrosion inhibitors in antifreeze become depleted, coolant Ph changes, and destruction begins.
This is true even if the coolant appears clean and clear.
I flush and change every 3 or 4 years and after a couple years, I add a partial container of water pump lube/ corrosion inhibitor to strengthen the coolants partially depleted stuff.
Old May 5, 2018 | 06:09 PM
SENOR NOODLES's Avatar
a radiator shop can solder the top tank back on. Might be worth having the whole thing done. Keep it alive, don't go to the newer style aluminum.
jstluise
Jul 30, 2013 11:49 AM
twowheelwarehouse
3.4 Swaps
Jul 11, 2013 09:26 AM
Blacksmith04
Apr 13, 2008 02:24 AM
CTB
23
Nov 24, 2003 10:23 AM
