To upgrade or not to upgrade
Old Feb 6, 2018 | 01:49 PM
NYHumpinUtah's Avatar
Hi guys, well I've looked around and I didn't find anything on this subject. I am doing a frame up re-build of my 84 reg cab. I'm thinking while I'm at it to upgrade the braking system. Watched a lot of youtube vids on this but none of them tell you exactly what parts to use. I want to stick with all Toyota parts but have something better then what is on the truck now. So my question is, should I update the system or just rebuild what i have. The truck is not going to be an off road truck but rather a looker. It will have a 3-4 inch lift and be running 31s
Some of the upgrades would include, 1" MC, dual brake booster, bigger calipers and pads for the front discs The back brakes I plan to leave as drum brakes and leave the LSP&BV as is.
The other question is, what parts fit? How would I know what to buy from what truck so everything fits? Anyone have a link to someone who has done this? I'm sure someone has done this here.
Any thoughts on this?
Thanks
Old Feb 6, 2018 | 02:02 PM
RAD4Runner's Avatar
Focus on restoring it to stock, first. If you're not happy with the brakes, then upgrade later.
I have stock brakes on my 1986 that's taken me all over the place. Haven't seen the need to upgrade, yet.
Old Feb 6, 2018 | 06:00 PM
L5wolvesf's Avatar
Agreed, I have not had any issues with the brakes on mine. The 22R is not the fire breathing, horsepower demon it looks like.
Old Feb 6, 2018 | 10:44 PM
Co_94_PU's Avatar
You won't need a three inch lift for 31 inch tires, and the factory brakes are plenty stopping power (especially if it's not being offroaded)..
And speak for yourselves, mine is totally a hotrod turbo and 12 inches of exhaust, I get all kinds of rubber necking and all kinds of guys hanging out the window with big thumbs up.. Lol
Old Feb 7, 2018 | 10:59 AM
Ok, 3 for 3 so far
So, you guys wouldn't do "anything" to improve? Interesting.
Any brands for brake parts you recommend, I know Toyota, but don't want to do a re-fi
Old Feb 7, 2018 | 11:19 AM
muddpigg's Avatar
Minor upgrades would probably be worth while. LC60 rotors, V6 calipers, dual diaphragm booster if your replacing the parts anyways it is cheaper to do it now than build it to stock form to then want more and then upgrade. These topics are covered in the faqs. The rear wheel cylinders can be swapped out with LC 1" ones forget the year, but you have to grind on rear shoes a bit.
With 31's you won't have same braking concerns as larger tire crowd.
Old Feb 7, 2018 | 11:26 AM
RAD4Runner's Avatar
I'm happy with NAPA rear brake cylinders and non-premium rear brake pads, here: https://www.yotatech.com/forums/f116...5112-a-301148/
I guess fixing things that broke or were done wrong in the first place are the best upgrades. Things I FIXED:
  • Rear suspension sag with a Zuk mod, and I now have 31-inch tires with the stock height.
  • Starter relay wiring that was done wrong at the drawing table and at the factory.
  • Flawed headlight wiring, again that was done wrong at the drawing table and the factory.
  • Poorly-designed and DIM deck lamp switching, so when camped in the back I would not have to scramble to the driver seat to turn on running lights just so I can turn on the deck lamp.
  • Poorly-designed rear window control, so when camped in the back I would not have to scramble to the driver seat to turn on ignition just so I can open the window from inside the rear deck.
  • The fact that my truck did not have a light reminder relay so I could leave light on and drain my battery.
Old Feb 7, 2018 | 11:28 AM
irab88's Avatar
I've had good results with Centric and Napa brand brake equipment. I just put Napa stuff all-around on my truck, and it stops like it should.
Like others have said, stock is more than enough. It stops my V6 just fine, and I had no issues when towing a small camper.
Old Feb 7, 2018 | 11:31 AM
RAD4Runner's Avatar
Originally Posted by irab88
...It stops my V6 just fine, and I had no issues when towing a small camper.
I notice slightly longer braking distance when I upsized to 31's. However, it's not much, I get used to it and I drive conservatively; foot off the gas as soon as I see brake lights or red traffic light ahead or 1/8-mile from freeway off ramp
Old Feb 7, 2018 | 12:50 PM
Ok, slow down, I'm pretty new here..........
LC60 rotors? From what?
V6 calipers from what?
Booster from what?
These topics are covered in the faqs Where is that?
Old Feb 7, 2018 | 02:00 PM
L5wolvesf's Avatar
Originally Posted by NYHumpinUtah
Ok, 3 for 3 so far
Check Rockauto, they carry a variety of good brands at reasonable prices.
Old Feb 7, 2018 | 02:36 PM
LOL, I was just looking on there
picked these so far for the rear
http://www.rockauto.com/en/moreinfo....sn=439&jsn=439
http://www.rockauto.com/en/moreinfo....277243&jsn=831
for the front
http://www.rockauto.com/en/moreinfo....277243&jsn=759
http://www.rockauto.com/en/moreinfo....277243&jsn=762
http://www.rockauto.com/en/moreinfo....277243&jsn=802
But they don't have the rotors
Thoughts?
Old Feb 7, 2018 | 02:46 PM
L5wolvesf's Avatar
I'm quite happy with Centric parts, I have them on one of my race cars (off road). Centric is a seller on eBay compare prices.
Worst thing about Rock is the shipping - preview the sale with shipping before you spend.
FWIW, I would get a kit and rebuild wheel cylinders if they aren't trashed.
Old Feb 7, 2018 | 03:17 PM
Yea, shipping is a bit much. Thanks for the high five on Centric, wasn't sure but everything I read says they are good. When I get to tear down stage I will check all but I still want to replace everything. Just getting my ducks in a row...........
I now have all the parts for the solid axle rebuild, all new Trail Gear stuff.So brakes are next on the list for the front, just calipers, rotors and pads.
Just ordered my new 60 gallon compressor to power my new sand blast cabinet and portable unit. Got a used oven and wired it in so I'm ready for powder coating, this is fun............
Old Feb 7, 2018 | 03:18 PM
muddpigg's Avatar
Booster from what?
https://www.yotatech.com/forums/f120/toyota-faq-66255/
http://www.pirate4x4.com/forum/toyot...faq-2-0-a.html
https://forum.ih8mud.com/threads/tru...stions.151199/
http://board.marlincrawler.com/index.php?topic=19277.0
If you want about the biggest brakes you can get for a SFA rig; Front Range Offroad brackets, Tacoma or 4rnr rotors and calipers. One of the possible set ups requires 17" rims to clear calipers. Only reason I mention it as its not mentioned in any of the faqs I linked.
Old Feb 7, 2018 | 04:55 PM
L5wolvesf's Avatar
12 inches of exhaust - long or wide?
Old Feb 7, 2018 | 05:31 PM
Well, homework done here's the results:
All brake parts for front and rear, all Centric including: rotors,pads,calipers,drums,shoes, and cylinders:
Ebay Total= $364.41 shipped (picked the best price available)
Rock Auto Total $ 306.06 shipped + $40 return core charge each, $80 refund, Final total $ 226.06
WOW, even with the $34 97 shipping from Rock Auto it's WAAAAAAY cheaper. The big difference is the cores.
Old Feb 7, 2018 | 05:59 PM
L5wolvesf's Avatar
Interesting, the Rock prices may be from a retailer or wholesaler buyout. I would still rebuild the cylinders - just sayin
Old Feb 17, 2018 | 09:18 AM
Irab88
Stock is fine if you already have a V6
Is yours a V6 with the V6 calipers, dual booster, 1" master and vented rotors? What year is your truck and will the parts from yours fit mine?
Thanks
Old Feb 18, 2018 | 12:56 PM
Anybody know what brand this is?
