Transmission ?? what is compatible??
Old Jan 20, 2019 | 07:46 PM
Diego toyota's Avatar
Good day one and all!
I am in the process of doing a Transmission swap once I figure out what year
is compatible with my 91 toyota, 22re 2 wheel drive .A job I will be doing on
my own, thanks to you guys an the Haynes manual. Finance is tight right now,
this is the reason I am searching for a use transmission, something I can afford
at this time. I have found a few on craigslist, but I have been unsure of what year
is compatible with mine that I can use, and does it make a difference if it is from a 4 wheel drive, or if
it is carburetor? Thanks!
Old Jan 20, 2019 | 10:48 PM
old87yota's Avatar
You will need to know what transmission you have in your truck. The transmission code is on the VIN plate as shown below:
Diagram source: 4Crawler
I would guess you have a W55 5-speed manual transmission, but check the VIN plate to be sure.
You will need a transmission out of a 2WD truck. It does not matter between carbureted or Fuel Injected.
Old Jan 21, 2019 | 05:51 AM
Good morning Jake, yes it is W55, 5 Speed. My main question is What year range should I search for when it comes to my transmission? I am unsure of that bracket of years.
what other year besides my 91?
Old Jan 21, 2019 | 09:53 PM
old87yota's Avatar
I am not 100% sure, but I think all 1989-1995 W55 transmissions from these trucks were the same.
The earlier versions (1988-ish and earlier) had a different shifter base.
tv4184
12
May 5, 2005 11:24 PM
MudMonkey
Feb 25, 2005 10:13 AM
Mudd Runna
Apr 13, 2003 05:53 PM
