Radio out
Old Jan 4, 2018 | 05:45 PM
yotaforever's Avatar
Radio out
The radio in my 85 pick up half ton long bed carborated 22r engine is out. Previous to this, I had hooked up the battery cables wrong being an idiot. The truck wouldnt start so I replaced the ICM and an 80A fuse under the hood. So the truck runs now. I also replaced fuses by the kick panel. The radio is out still, any ideas?? Thank you.
Old Jan 7, 2018 | 09:19 AM
se7enine's Avatar
If it's an aftermarket radio it probably has a burned fuse on the back. Not sure if stock radios have fuses on the back though.
Old Jan 7, 2018 | 09:24 AM
Co_94_PU's Avatar
Pull the radio, locate the power and ground wires on the harness and probe them with the radio disconnected. Attach a temp power and ground to the radio and test it out of the truck, its likely dead because it didn't have a reverse voltage protection diode.
keycw
Jun 26, 2025 06:18 AM
atcfixer
Dec 6, 2018 10:51 AM
93Xtra-Cab
Aug 8, 2018 05:23 AM
dakotawho
Jan 4, 2018 02:33 PM
tommmalone
Dec 11, 2017 05:51 AM
