Transfer case removal.
Old Mar 29, 2018 | 12:56 AM
Horseflycrawler's Avatar
I need to rebuild my transfer case on my 84 2L pickup. The service manual says I need to remove the transmission and transfer case as one unit. I'm wondering if I really need to or can I split the tranny and transfer case in place. I've been searcher around on the internet and I can seem to find a positive answer one way or the other. Thanks,
Old Mar 29, 2018 | 07:02 AM
dropzone's Avatar
Fossilized
If it's an automatic the transfer case is integrated to the transmission
if it's a manual transmission
pull the selector out through the top
remove speedo cable
remove both drive shafts from the outputs
undo the 6 bolts going from t/c to transmission and slide the t/c out and down
you will wanna have a strap or some other means to support the transmission or you will put strain on your motor mounts
74fj40
7
Aug 25, 2019 05:58 AM
shadowbirdie
Apr 10, 2015 02:55 PM
quadmaster224
Mar 22, 2015 10:23 AM
4wheelingyota
Aug 30, 2010 04:45 AM
survivorman97
Aug 10, 2009 05:28 PM
