Hub stud Torque specs needed ?
Old Feb 27, 2018 | 12:48 PM
badgas1's Avatar
Hello
I'm getting ready to install new studs to mount the Aisin locking hubs. I don't have a FSM and can't find these specs. Some say finger tight, a youtube by low range says to double nut and use an impact until they stop ? does anyone know the factory specs ?
Thank you for the help
Old Feb 27, 2018 | 05:57 PM
millball's Avatar
I doubt that there is an actual spec for setting those studs into the hub.
I'd just double nut them and turn them in until they stop with moderate force on the rachet, or box end wrench when the threads bottom into the body of the hub..
I sure wouldn't pound 'em in with an impact.
The Haynes manual I just consulted says 21 to 25 foot pounds for the top nuts that retain the locking hub body on those studs.
Old Feb 27, 2018 | 06:03 PM
YOUNGIAM's Avatar
X2 and I would add blue lock tite
Old Feb 27, 2018 | 10:13 PM
Co_94_PU's Avatar
Thread size, bolt class, threaded material, determine the torque amount.. One of the two charts above has the information..
Old Feb 28, 2018 | 12:19 PM
badgas1's Avatar
Thanks guys
That is what I did, snug little blue thread lock . I didn't need to double nut them as my kit has a 6mm head on the stud. The only reason I noted the impact is that Low Range has 9 part how to video and thats how they did it.
Kevinsarnecki
Dec 20, 2016 03:21 AM
SCToy
Apr 25, 2011 05:09 AM
JohnStra
33
Apr 6, 2011 11:41 AM
Cliff96SR5
Oct 13, 2006 01:56 PM
