LSPV [Load sensing proportioning valve] Interchangeability
Old Aug 22, 2018 | 03:03 PM
eightnine's Avatar
Has anyone tried using a 1986-1988/9? 4Runner/Truck [P#: 47910-35090/47910-26040] on a 1984/85 Toyota 4Runner or Truck [Original P#: 47910-35080/47910-26111]?
I am trying to use a newer LSPV on my 84 4WD and not sure if the different P# changed due to some internal change on the unit?
Thanks for any assistance.
Old Aug 22, 2018 | 07:43 PM
Co_94_PU's Avatar
Not that I am aware of, but that list is growing everyday..
Put it in, test the line pressure and you can tell us.
Old Aug 22, 2018 | 08:15 PM
SheepishLion89's Avatar
I just removed mine from my 85 4runner. Got a manual a manual valve. Wildwood has one with 10mm threads that bolt right on.
Old Sep 22, 2018 | 06:52 AM
Installed. Not great but works. Want to replace all brake lines in the near future.
Old Sep 22, 2018 | 07:51 AM
Co_94_PU's Avatar
Just pointing out what should be obvious here..
A manual valve is not equivalent to a load sensing valve.
The whole point of the lspv is that the line pressure is correct regardless of what's in the back your dog or a pallet of lead...
Old Oct 18, 2018 | 07:28 PM
Agreed with the above. Will depend on your application and requirements. In my case, a manual valve was the best choice.
bvrettski
Jan 25, 2020 12:41 PM
semo
Jan 31, 2008 09:10 PM
andrew241
Aug 13, 2007 04:54 PM
nicka
Nov 22, 2006 03:52 PM
