Lce pro distributor install
Old Dec 15, 2018 | 01:30 PM
Pri$erulz's Avatar
hello,
im putting a LCE pro distributor onto a freshly rebuilt 22r engine and am a little confused here. I am trying to learn and do everything myself but need a little guidance. If it matters, and I don’t think it does, this is a carbureted laser block.
The manual for my ‘81 says to set the timing at 8 degrees before tdc and install the distributor with the rotor point up. Upon seating of the distributor it will rotate to the 10 o’ clock position. I pulled the new distributor out of the bag and slide it in. When I removed the cap my rotor is sitting at the 5 o’ clock position.
Does this mean that the engine was not at tdc and is 180 degrees out? Is this the advance of the distributor? Or was I supposed to remove the cap and set the rotor to the 12 o’ clock position before I installed it?
In my simple mind, it would make sense that I do not have the engine at the correct timing before the installation. It would seem strange for LCE to ship someone a product that is not ready to be installed.
Old Dec 15, 2018 | 05:08 PM
se7enine's Avatar
You have to remove the cap before you install the distributor. If you still had the cap on then you wouldn't have known where the rotor was pointing. Just like your manual says :
Old Dec 15, 2018 | 06:56 PM
Pri$erulz's Avatar
Roger that. That means the timing advance is internal to the distributor that LCE makes and I will install it just like a normal distributor. What are the chances it fool the smog guy?
Also, just for knowledge, if I left it installed as is, my engine would be misfiring like crazy and maybe not even run?
Old Dec 15, 2018 | 08:30 PM
Kolton5543's Avatar
Engine won't even attempt to run run in that position. Make sure the engine is at TDC compression pull out the distributor enough to disengage the gear. Rotate the rotor to the 12 position and seat the distributor again. Should be good to go.
Old Dec 16, 2018 | 12:54 PM
Pri$erulz's Avatar
Right on. Thanks.
bootscootboogie
Nov 17, 2015 05:45 AM
87tyota77
Feb 23, 2014 06:47 PM
beach_yota
Jul 30, 2012 01:05 PM
Green93
Apr 29, 2008 08:05 PM
toyotatom93
Apr 17, 2008 05:03 AM
