PDA
View Full Version : 86-95 Trucks & 4Runners (Build-Up Section)
Pages : 1 2 3 [4] 5 6 7 8 9
  1. Roark's '89 pickup build
  2. bogs0315 1987 pickup
  3. JustDSM's 1993 4Runner Build
  4. 1988 Toyota 4Runner
  5. Robinton 1989 4Runner Buildup Thread
  6. NashuLee's 1989 4 Runner Build Up 'Lil Blue -- The saga begins
  7. My 94 Clean up/Build up thread!
  8. 88 toyota flatbed troubles
  9. mxdw88_1988_"Falcon"_4runner_Build
  10. Rob's 94 SR5
  11. my 94 pickup build aka" domo" build
  12. 87 4runner with 22RE burns gas
  13. 89 Pickup. Mean and Green
  14. 3.0l carbon covered spark plugs
  15. Gear ratio 88 toyota 2:1
  16. Mr. Orange and his Orange Pig
  17. my 94 4runner bumpers
  18. SCEMIPDX's '94 SR5 Pickup
  19. SheepdogGadget's '88 Pickup slow build thread
  20. My toy
  21. DJTC's 1990 Pickup 1.9 TD to MTDI !
  22. nedhills 1992 Toyota Pickup build
  23. chukarhunt's 1992 "Jake" Pickup Build-up Thread
  24. 91 pickup build
  25. 89 3.0 pickup. clutch fan vs flex fan
  26. 95 Runner Transmission Cooler
  27. 36x12.50 to big for IFS
  28. 88 pickup roll bar probs
  29. Grimur's 95 sr5 pickup aka "Tammy-Lynn"
  30. A couple of issues. worth my time??
  31. Chefyota4x4's Ruby R3dRuM to "Suzy-Q the Silverback" Body Swap Thread!
  32. swapping to manual transmission
  33. Summery of the 1994 pickup rebuild, 22re
  34. Grawg's 86 4Runner
  35. tinigunner's 1986 4runner build.....again....
  36. 22RE build (lucas break in additive)
  37. 3.0 to 22R wiring help
  38. 93 4runner build phase 1.0
  39. Buggy's '89 pickup build!
  40. 94 4runner suspension rebuild
  41. reichard117's 1992 4bang5peed pickemup
  42. str8cr8's 86 propane toy
  43. 80/86 cross restoration
  44. 89 4runner (Beasturrito)
  45. Blood, sweat and beers. Rampart Rangers Runner
  46. 22rte CT26 Swap
  47. Bed side pieces
  48. 1986 4runner 22re, m/t very violent clunk when in 4wd!!! please help!!!
  49. 22re Stuck headbolt
  50. Stuck headbolt
  51. Jeffe's 1990 4Runner build
  52. lots of 20r motors and want one in a 4runner
  53. 94 pickup leaf springs?
  54. My belts are starting to whine a bit more than usual. 1992 v6 3.0 liter 4x4
  55. Wiring Issue with a pair of Hella 1000: When switched off they won't come back on
  56. 3.0 throttle body
  57. Need help finding some bolt ons
  58. 91 Surf 2lte newbie buildup
  59. jason in tn`s 88sr5 MyToya88 build
  60. 95 Toyota 3rd member help
  61. 22re build help! (first time rebuilding)
  62. Broke and driftin SAS
  63. 1989 2wd rear differential information
  64. 91 toyota ext-cab sr5 build
  65. 87hoerunner's 1989 4runner build
  66. 93 4Runner build
  67. 2x2runner '88 4 runner build
  68. 94 runner sway bar problem
  69. Mak92-4RnR's 1988 4Runner Build
  70. 93 landcruiser rough running and idle
  71. Heavy Duty Work Yota 4x4
  72. Mountaineer's 1994 Pickup Build Up Thread
  73. 95 4runner build up
  74. New to me 94
  75. back up camera 5 spd 1990 toyota pu
  76. 88 4runner three link rear
  77. Need to find out where sensor near the Oil Pressure sensor goes.
  78. Ole Red 1987 87 4runner build
  79. 86toyotaprerunner14's 86 prerunner
  80. 86toyotaprerunner14's 1986 toyota prerunner
  81. 1986 toyota pre runner
  82. 1988 4 runner 400 small block
  83. 89 Extracab, FZJ80 axles
  84. bamaboy's '89 build thread
  85. 4wdYotaBoy's 1988 4runner a broke 16 year old who can't afford to build it but is
  86. Its a turbo baby!
  87. 86 Pickup 22R-TEC to LS1 or LT1 Swap
  88. ''hillbilly deluxe'' 86 toyota pickup build up
  89. 1UZ engine swap
  90. 1990 4Runner 3.0L Head gasket, water pump, thermostat, and timing belt change.
  91. 1987 Extracab 4X4 Weekend Warrior
  92. OM617 swap into my 93 4runner V6 5 speed
  93. Headliner help
  94. 22rte to 22re engine swap
  95. 87 Runner Zombie to Zombie crusher
  96. Phills 1993 4runner rebuild
  97. this is my project anti-hack
  98. shorting electical problem
  99. Joining the sas club!
  100. 412eRunner slight Build ***pic Heavy***
  101. 88 extra cab sas project RUF & 63 Chevy
  102. building a 90 short box
  103. 95 4runner build
  104. Dirt Digglers 87 truck aka "Chevota"
  105. Akdylan18's 1991 Toyota Pickup Build
  106. Need some help
  107. Header Recommendations? 1994 yota pickup
  108. Body mounts
  109. Power steering belt slipping
  110. 86 4runner on 89 pu frame swap
  111. buying shackles
  112. Starting 22r stroker project
  113. yeos 94 Pickup Xtra Cab V6
  114. Project Shapos 2
  115. enelson95's 1987 Toyota Pickup 4x4
  116. 92'blue4runner Trail truck/Bogger Buildup thread
  117. piece of sandpaper fell in water gallery
  118. 94 toyota 22re, no pressure release when gas cap removed
  119. Matt1992's 92' 4Runner Rear Quarter Fab with FENDERS!!!
  120. Redneckninji20s 89 pickup build
  121. CJ94yota 's 1994 Ext.Cab Pickup Build-Up Thread
  122. HoP's Toyota Rigs
  123. difference 88-92 vs 93-95 3vz
  124. MaltDisney's '86 4Runner brought back to life
  125. Taylor's 1993 Fo'runna
  126. MaltDisney's dual 4runner build up-'86 & '94
  127. Luthiermans newb questions for an engine rebuild
  128. Fried onion's 1987 4Runner Rust Bucket Build-Up
  129. 1991 Toyota 4runner Build Ideas?
  130. Andersej: 1993 2nd Gen 4runner
  131. Toyotaguy's 22re custom turbo build
  132. 1988 Toyota SR5 turbo
  133. arlindsay1992's 1987 4Runner Build Up Thread
  134. 1987 sr5 custom cab toyota with a 22re-t
  135. 87 4runner intermittent starting issues
  136. Revilo's '94 4Runner Build-Up Thread
  137. Ijjiop's 92 4x4 pick-up build
  138. 1986 4runner buld 4bangin
  139. Chris's 89 Hilux Trail Rig from Aus.
  140. 3rd gen pickup build
  141. chevy 63 front hangers
  142. tylers 89 alaskan beater
  143. PacNW Daily Wheeler Build.
  144. 22RE Distributor "Cotter?" "Pin?" "Dowel?"
  145. Fetch's 87 Yota build in ND
  146. 95 22re 4wd Reg Cab
  147. Back In It
  148. MY PROJECT 86 Toyota PICKUP
  149. 1991regcab4x4 1991 pickup super dope build thread
  150. Jake's not much of a 92 Pickup Build
  151. Rebuilding the Green93
  152. ever wonder what a $900 4 runner looks like? rjfortuna 1995 4runner
  153. Cartertannahill971's 1987 Toyota Pickup
  154. 1986 toyota extra cab...good start
  155. Thedirtdaniel's 88 Pickup Build/I'm new
  156. Sam's 89 IFS rig
  157. Dinardy's 91 SR5 4runner
  158. photoleif's 1995 PU build-up thread
  159. 89 yota with hydrolocked engine worth buying?
  160. Dswag's 93 Extra-cab
  161. Troy's 93 pickup (somewhat) build
  162. Gevo's 91 4Runner Build Thread
  163. 7m4x4dude's 87 4runner family rig.
  164. Cookie Monster's '87 P/U Build Thread
  165. 22re rebuild
  166. cwapface's 1987 Pickup Restore Thread
  167. Wnting to swap a 3.0 in a 1990 pickup!!!
  168. Fjtoymans 1994 extra cab build
  169. M44offroad's 1987 4Runner Build
  170. Matt's 93 3.0 buildup
  171. HELP with 351 Windsor swap
  172. Kirk Payne's 1994 Extra Cab Build
  173. 1986 Toyota Pickup Need Info.
  174. how to replace the water pump in a 3.0
  175. 88 EFI Stepside build
  176. Daenerysdad '93 DIY Blazeland long travel
  177. 1uz buggy finally running
  178. Roof Rack Question
  179. RL's Build Thread- 90Runner
  180. Transmission Problem (...Overheating??)
  181. Pulling the wiring harness.
  182. Cr@ves4wheelin 1990 Hilux Build Up Thread
  183. 1995 4runner build up
  184. Crank too tight to spin.
  185. Speedcrazy's 94 Pickup REV 2.0
  186. 1988 Toyota Pickup Build
  187. 22RE Head-ache! Opinions
  188. How do I calculate the offset
  189. 92 Hilux Street Truck ( LT. DAN )
  190. transfer case!!!!
  191. 1987 4runner build up
  192. 22re no timing advance
  193. Bump's '90 4Runner Build-Up
  194. 94 cheap runner
  195. JB's 1990 4Runner Build Extravaganza!
  196. Drove it home now it wont start.
  197. Mr. Gold444's 1986 Pickup build
  198. 95.5-97 front end swap...possible?
  199. 4x4yota's 94 SR5 4runner
  200. Fuel Cell Power
  201. 90 pickup 350 swap
  202. LosPatos 93 runner swap and build-up
  203. Rear Seats
  204. ChefTank 1994 4runner build
  205. Dswag's 87 4runner
  206. Camshaft/Head upgrade 22re
  207. Airborne173rd's 1989 pickup buildup
  208. 1987 22R 4x4 300k need bottom rebuild??
  209. 1987 XtraCab small mods
  210. First time Toyota owner.. clean up!
  211. Selk78 92 hilux build
  212. 1987 Xtra Cab SR5 resurrection
  213. Remanufactured parts wanted
  214. kawasakilewis' 89 4Runner build up
  215. 92 4runner 3.0l v6 valve an timing issue
  216. 3VZE Duct Sub Assy, Cool Air ???
  217. 1993 EXcab V6 build up
  218. My Junkyard Truck! Saved from the grave
  219. Big Bear's 90 4X4 3vze Runner, POS to DD Build
  220. ajstoy 1986 pickup
  221. OLTOY's 87 4runner build
  222. 1987 toyota pick up 4x4 lifted
  223. Cougar House Garage's 95 TRunner 4WU 3-link an 4-link build
  224. 86 turbo truck, 1.9 tdi build
  225. Fuel Pump and Tank!
  226. Jlaughlins 1993 ext cab build
  227. Jlaughlins 93 x-cab yota build
  228. 93 x-cab build
  229. 1994 Toyota 4runner missing
  230. Just bought my first yota!! :D
  231. 1994 turbo 4runner
  232. RaunchBox's 1990 4runner build thread
  233. kushiel's 1987 4Runner
  234. Nuttynu's Pickup build thread
  235. 1993 Toyota Pickup Help
  236. The4RunnerHouse's 1988 pickup build-wrecked but reviving
  237. CougarHouseGarage's 1995 4Runner SAS an 3link build
  238. Magichelmt 1988 Pickup
  239. Lockers
  240. J_yota22k SAS 91 toyota pu build
  241. 88 yota truck and 94 4runner dd
  242. Thoryota 94 pickup build-up thread with lots of pictures
  243. 88YotaBomb's - The rebirth of a 1988 Pickup
  244. 2 toys 94 4runner build
  245. JeremyW94's 94 Pickup Build
  246. 1987 toyota 4runner sr5
  247. kg206's 1992 Pickup Build-Up Thread
  248. 89 2wd 3rz swap
  249. Question on Harmonic Balancer.
  250. 3.0 Headgasket help
