piece of sandpaper fell in water gallery
Old Nov 4, 2013 | 05:55 PM
Ryan G.'s Avatar
Ok don't laugh but while sanding down the head gasket surface of my 22RTE block a little piece of sandpaper fell into one of water galleries next to cylinder #3. . Does anyone know where these particular water galleries run to? Does it run to the radiator next or to smaller galleries? I tried fishing it out with coat hanger but that didn't work. I have since installed the head.
I was thinking about disconnecting the lower radiator hose and cycle some water through the thermostat opening via a garden hose. maybe even crank over the motor to circulate the water.
Looking for feedback before i do something i shouldn't and force the sandpaper deeper into the engine.
Old Nov 4, 2013 | 07:29 PM
kawazx636's Avatar
Try using a vacuum to suck it out. I've actually rigged up a 3/8" piece of hose to connect to my shop vac suck stuff out of tight spaces. Works well
Old Nov 4, 2013 | 08:33 PM
David_315's Avatar
Thanks for the shop vac idea
dumpster84
Apr 30, 2016 06:03 AM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
HookahRoo
Jul 20, 2015 07:06 PM
PlayAwhile
Jul 20, 2015 11:36 AM
