- Who is Toyota using to make new 22re engine
- Clinometer install
- custom rear bumper 92 4x4
- J&HFabs 1989 4Runner build thread
- Backup Camera/Reverse Light Interior Wire Location
- 1988 Toyota pickup 22re intermittent jerking at 70 mph
- Which wheel cylinder????
- Reliable engine builder Salt Lake
- 1987 4Runner Purchased Fall 2024
- 22re bogging randomly
- Running rough, but intermittently: 22-RE
- '88 22re cranking and wanting to start but wont
- Body work ??
- 1992 pickup 22r 38 weber
- Torque converter lock-up override???
- 22re code 31 on 89 pickup
- 1988 P/U neutral safety switch question.
- Brakeline Brackets/mounts on Firewall
- 1990 4runner 3.0 auto to 1997 2rz engine & manual swap
- No lights nightmare 22re 1994 toyota pickup
- Engine rebuild valve tearing sound?
- 3VZE Power steering squeal
- 94 22re pickup idle issue
- Piston/Deck Quench Height
- 87 4runner 22re 5 speed re-gear question
- Piston Condition for rebuild 22RTE
- Scanner for a 93 4x4 SR5
- Dad gave me his '92 Pickup!!
- Lofty47's 94 pickup build
- Slide In Camper Suspension Help
- Suspension Build For Heavy Load
- FREE Hood Strut Kit (90-95 4Runner/89-95 pickup)
- Build ideas?
- Hose Replacement question
- 1989 Pickup 3VZE to LS Swap
- rustEd's 91' Extended Cab Build
- Climate control LED replacement
- Slave Cylinder and Cruise Control
- 1987 Camper 22RE Engine - Fule Pump
- Aiming idle issue
- Idle Engine problem(s), (3.0L 3VZ-E) tried many tests with no luck 🙁
- Reverse Lights
- Trouble Shooting a possible dirty/defective AFM
- 1992 Hilux Diesel
- RCBondo’s 1989 22RE 4WD restoration
- 95 4Runner runs smooth starts to vibrate when truck is at a stop
- 1988 4x4 Toyota Chinook Camper
- 1989 4Runner - The build my friend couldn’t
- 1987 22RTE 4runner Restoration
- Project Dumpy
- First Gen 4Runner, Beater build with the kids!
- 89661-3d360
- 1991 v6 2 wheel drive injectors open on trying to start
- 86 22REC - NO click, no start?
- 94 3VZE Timing Cover Gasket?
- 3.0 unknown oil source
- Part Number Help for a Hose
- Frame rot question.
- 5vzfe computer
- 1992 Pickup SR5 - build? debuild? build down? Idk
- 88 thru 95 Toyota Pickup vent windows
- 1994 Toyota engine swap TDI 1.9
- Lubrication
- Gizler00's 1994 4runner build For Adventure!
- 2nd gen 4runner 3.0 kickdown cable
- My 1987 SR5 ROAR (Restoration Of A Restoration) thread
- 86 4runner gets a fresh 22re
- §993 4Runner 3.0 manual, VSS1 sensor test from instrument cluster
- 1994 4Runner distributor question/issue
- Germans don't work on older cars, any advice for superior German mechanics?
- Hairyberry build
- 1990 Pickup 3.0
- Choosing compatible aftermarket fuel gauge
- Transmission Problem? 1986 Pickup not engaging in fifth gear.
- Suspension recommendations? 93 4x4 pickup
- toy 89
- Low Brake fluid pressure
- Ignition Switch wire identification
- Melrose’s new project: “Half Full”
- 3vzsurvivor 1990 3rd gen Pickup SAS build
- Weber 32/36 carb leaking
- 1988 1st gen 4runner build
- Black Pearl vs. Hawaii rust Build
- 1986 4WD pickup - windshield corner rust fix?
- wally's 874runners continuation thread from t4r.org
- uncletito's 1995 4Runner Build
- Japanese cylinder head...NOT Chinese
- Full floating dually rear axle
- Scrappy Jackalope 2nd gen 4runner Long Travel Build..
- Knucle steering broken
- 22RE Clutch Replacement Question
- 91 Pickup SR5 wheel arch molding search
- 1989 Toyota Pickup 22re
- NorCal Oklahoma Build up & 5VZ 3.4 Swap
- Smog Pump
- Project Recycle - 1994 4Runner
- Leaf spring identification?
- 4runner automatic transmission mods
- replacing shocks
- NoVA body shop -88 4Runner SR5
- McDevitt Machines' Barn Find 1986 Pickup Restoration Video Series
- MegaSquirting the 22RE in a 1986 Mini Cruiser RV
- 1993 4Runner - a rusty rebuild
- Part number for Pipe assembly under Plenum 3VZE
- HELP! 1990 4 runner fuel tank ETC
- 1992 pickup
- 1986 4Runner alternator
- Clifford the 1990 toyota pickup!
- White 1992 Toyota Pickup DLX
- Vman455's 1991 Hilux 4WD 22RE updating and preservation
- It all started with a 3.4 swap, Ruby the 93 is slowly growing
- Toyota pick need help badly
- maxvp01's 1989 Toyota Pickup Build
- weety's 1990 restore
- 1989 Toyota Pickup "Happy" - Regular Cab 22RE - Build Up
- Slow but Forever 89 Single Cab 3.0 Build Thread
- '89 T4R Build, Restore, Mod?
- 4WD Swap
- Home made cup holder
- 88' pickup decklamp removal
- STERFRY's 1986 SR5 4Ruster build
- 1987 turbo partial resto
- 1988 4x4 truck 22re back to new
- Tom's "Maintenance is key" zippy build
- Stumped - hoping for advice :)
- 2nd gen 4runner custom front and rear bumper plans
- 1988 Extra Cab SR5 Build
- 86 Pickup buildup (In progress)
- '95 $runner Head gasket job.
- 1994 toyota pickup cranking but not starting
- 1994 Toyota pickup 4x4
- 2nd Gen 1995 4Runner A340H Transmission - Intermittent No Reverse
- What have I started?
- chassis swap 4runner
- Is the blackout look worth it?
- 1988 4runner build
- The Taz build
- Eskay's 1990 22re Pickup
- Help! 1990 22RE 4cyl Pick-Up Kill Switch
- 1994 Toyota deluxe pickup 3.0 V6 overhual
- 3” body lift fender wells
- 1994 Toyota truck 22re, damage Head gasket working on timing cover
- Wiring Help Needed
- 1992 Pickup brake light issue
- gerth92's '92 2wd on a '80 4x4 frame
- Truck ADD strikes again... ('93 X-Cab SAS)
- Do I need again an new ECM?
- Brake light, battery light, and a/t hot light stayed on after startup...
- 1989 toyota crank no start
- 1987 Toyota PU 4x4 Clutch Pedal Issue
- My first Toyota build 88 pickup
- Transmission will not upshift
- Another 86 SAS
- Drmix's 92 4Runner 22RE Build
- Frame swap and sectioning
- Door panel fabric diy
- 302 v8 build factory tach hookup.
- my 1989 toyota revival
- Yoterr's "The Streak" revival build
- 1995 t100 no power to headlights/radio/clock
- 1992 Desert Pickup Rehab
- Another long term 95 resurrection
- Back from the dead (again) 1990 4runner gets a new engine and a whole lot more
- 1994 toyota pickup 22re t3/t4 custom turbo
- 22r to 22re
- 1991 PU 2wd lift
- '93 3.4 Daily driver
- 1993-1995 rear chrome bumper
- 1992 4cyl 2wd - tire upgrades?
- Complete 2WD Rear Ax Swap Possible? 1983 to 1994
- NickMiller's 88 Redemption Build
- 91 pickup restoration
- One cam cap bolt not torqued to spec, locktite, problems?
- New to me 1988 Build
- Pickup Door Sills - How to Find
- 3vze starts then stalls
- Head Resurfacing
- Rain gutter weather strip
- Shirley's Demise
- 1989 White Knight Pickup SAS Build
- 87 Xtracab, first Toyota
- 22re turbo build
- 22re/ for those who had to drill the thermostat bolt
- 5 Fist's 87 SR5 4Runner
- My first yota 91 single cab
- 22re build
- 1993 4R Build Thread
- Ricky's 1990 4Runner Build
- 87 HVAC Control Switch Bulb Replacement
- 1986 "Stubby" Xtra Cab Build
- 88 yota truck needs beefed up
- TLfromAI's 1991 4WD Pickup DLX Build
- Hump's 92 4Runner build
- 1993 Toyota Pickup dies after I hit a pothole??
- Dirt Garage / 1989 Pickup Build!
- RN101 Build
- 88 4runner "Danger runner"
- 1990 Toyota Pickup 4x4
- Long travel IFS
- 1987 4runner Build
- "Tango" UK 1st Gen Surf
- 1989 Hilux LN105L
- 94 yota pickup (Drift project)
- 92 4runner build
- 1989 Toyota 3.0 pickup won't start
- Toyota 1988 4Runner rebuild
- Rookie Build Thread
- Project daily driver 1991 4Runner
- 1986 4Runner IFS Baja Build
- 89 work toy
- 1993 Project Pickup
- New to forum, a few pics and a few questions
- 1988 4Runner Resto
- 93' 3vze Valve Stem Seal Replacement
- 86’ 4Runner Build and Help
- Ruined CV or Front Diff
- 1990 Truck (3.0): Rebuild Project + DD
- tyvanwie's Project: An 86 Pickup Rebuild
- My 88 Pickup Build--Post SAS
- Restoring a '93 4Runner SR5 V6 4x4
- The story of Veronica, my 90 4runner
- 89 Pickup Build. Project cream puff trail rig
- 85-95 Cable bracket Anyone know where I can get one?
- Has anyone on here happened to see my old 93?
- "Beater" build thread
- K91776’s ‘87 4Runner build
- My 1986 T4R build
- 91 4 runner 3.0 speedometer cable
- 22RE after flushing coolant error codes 24 and 31
- 22re header problems
- 88/95 4 runner
- wiring harnes 3.4 3.0 swap
- Cooling System and Temp Senders - 22RE
- Delete roll-up window and replace with flip-up type on first-gen 4runner
- Only on 4WD Clunk!
- My dream build!! 1986 Toyota pickup(Lucy)
- *FREE Yotatech Decals*
- 1990 4runner inaccurate speedometer
- A/T cooler relocation after header install. 3.0
- Intermitant starting problem
- The '88 Runner Grocery Getter
- 88 pickup - Low SAS tech
- 1993 Toyota 4x4 Deluxe Build Thread
- 1994 4runnwr build
- Caitlyn the 2nd Gen 4Runner-ish
- 86 22re build to supercharger
- RedYota93's 1988 Pickup
- 1989 Single Cab SAS Build
- 1989 Toyota 4runner SR5 -- Restoration & Modification
- I bought a $350 1995 4Runner...
