Cooling System and Temp Senders - 22RE
Old Feb 8, 2018 | 10:38 AM
RAD4Runner's Avatar
Cooling System and Temp Senders.
I'm posting info, photos, identification, etc on 22R-Eliable Cooling System and Temp Senders.
YOTARICK'S 1986 (I think he doesn't have stock coolant thermo switch (TSW-4WD) so I cropped the photo.
Actual Coolant Thermo Switch (TSW-4WD) on my 1986 22RE.
I verified that Coolant Thermo Switch (TSW-4WD) does not affect starting in normal conditions. I think this comes into play when coolant reaches a certain temp limit.
IMPORTANT: Coolant Thermo Switch relies on bare, shiny metal contact on mounting threads for grounding.
TIP: If re-doing the harness, take the wire for this out of the harness under the intake manifold and run it along the CSI timer switch and ECU Coolant Thermo Sensor; That's where it belongs, and you get less clutter under the already tight space under the intake manifold.
Coolant Thermo Sensor (THW) is connected to THW and E2 of ECU using same color wires in 1986 and in 1988 22RE.
Coolant Thermos Switch (TSW) also connected to ECU TSW using same wire colors.
Safe to assume it's same in 1987 22RE.
TEMP SENSORS CONNECTED TO ECU - 1986 MoreFunner
dieselcruiserhead
Nov 13, 2014 12:51 PM
mattaway
May 1, 2010 03:27 PM
dstn2bdoa
Feb 6, 2010 05:43 PM
dgz32
15
Feb 27, 2009 03:44 PM
