1993 Toyota Pickup dies after I hit a pothole??
Old 03-15-2019, 03:47 AM
77lubr's Avatar
I was coming home from grabbing dinner last night and I hit a pothole and then the truck died as if it is either not getting fuel or spark. Battery is fine and it will crank, but it will not start. Is there an inertia switch in these trucks that could need to be reset? It was around 9:30pm when it happened, and I left my tools and flashlight at the house like an idiot because I was moving some furniture a few days prior so I wasn't really able to test anything. That will be tonight as long as the rain holds up. Just wondering if you guys know where I should check other than the normal items such as plug wires and fuel lines? Maybe a fuel relay got knocked loose? Any help would be greatly appreciated.
77lubr is offline
Old 03-15-2019, 02:44 PM
Just read your issue and I have similar issue..........hit a dip, was running fine and now won't idle..........seems to run fine at highway speed but dies at idle.........by the way 84 SR5.......extra cab........not hijacking the thread but could be related. These trucks can't jump timing that easily can they.??
DAYLEY/CHALLENGER is offline
Old 03-15-2019, 03:46 PM
old87yota's Avatar
What engine is in your truck?
Your Truck does not (or should not) have an inertia switch.
First, you should make a list of what works and what doesn't work. Do headlights work? Turn signals? Dashboard gauges? Blower motor? Radio, etc....
If many of these things do not work, you have lost a main power or ground feed somewhere.
If the only problem found is that the engine won't start, that narrows down the potential causes to air, fuel, spark, timing, and the ability for the engine computer to work properly.
If you have a timing light, you can test for spark by attaching the inductive pickup to each of the spark plug wires. If the timing light flashes, you have spark.
IF you jump the FP and B+ terminals in the diagnostic box (using a bent paper clip or similar) and turn the key to the on position, you should be able to hear the fuel pump running. If you have spark and you can hear the fuel pump running with the jumper in, try to start the truck now. If it starts, then you have a problem in the Air Flow Meter - Circuit Opening Relay circuit.
old87yota is offline
Old 03-18-2019, 05:28 AM
77lubr's Avatar
I have verified that I have spark and all of my accessories are working. looking under the truck I noticed this wire hanging loose, but could not find the other end of the connector. I'm going to take the bed off this week. The bolts shouldn;t give me too much of a problem since it has a 2" body lift on it. I'll keep you posted on my progress.
77lubr is offline
Old 03-18-2019, 11:45 AM
RAD4Runner's Avatar
Like old87yota says ^^^.
Most likely a case of bad/loose connection.
Quite possibly, but we could not tell you where to check look if we don't know what engine you have.
ALWAYS indicate year-model-engine-transmission-trim in describing problems. I strongly-suggest you put that in your signature to (It would have saved us minutes or hours and posts if you did).
Originally Posted by 77lubr View Post
I have verified that I have spark and all of my accessories are working....
And these are while your engine is not able to have combustion?
... noticed this wire hanging loose...
What color?
Since you're removing the bed, best time to inspect fuel pump, mounting, wiring, etc.
RAD4Runner is offline
Old 03-18-2019, 11:53 AM
RAD4Runner's Avatar
Nice of you to not start another thread. However, troubleshooting two cases on one thread might get confusing - your symptoms are a little different from O.P. (O.P. does not get combustion at all), so please start your own thread. Of course, it would help to monitor this particular thread, especially if you share same engine.
Put us right at your truck; Let us see, hear, feel, smell what you are working on so we could most effectively help.
Put model-year-ENGINE-TRANSMISSION-trim on signature to prevent waste of time on questions and answers about what should be routine information.
Old 03-18-2019, 01:28 PM
Sorry about that RAD.Didnít mean to intrude. Understand completely. Found another thread that related more and posted there.
Old 03-18-2019, 02:02 PM
old87yota's Avatar
That wire isn't factory (judging by the connectors), so it is either a repair to a factory wire, or a wire for something aftermarket.
It looks like it is leading towards the fuel pump.
cambob
04-13-2012 03:17 AM
snap-on
Off Topic Talk
10
12-14-2005 02:47 PM
lee
18
03-07-2005 06:22 PM
RufusRunner
14
05-06-2004 11:10 AM
Quick Reply: 1993 Toyota Pickup dies after I hit a pothole??
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
