3VZE Power steering squeal
Old Jul 16, 2024 | 05:36 AM
2ndgen4x4runner's Avatar
I've owned a 1990 (many years ago) and now a 1992 4runner with very low mileage and mint condition. The steering squealed on both trucks when the wheel is turned all the way left or right. I see posts that say "just don't turn it that far". That's not a fix!! Is the belt too loose? Is this common on 2nd gens? Is there an obvious simple fix? Thanks for any feedback.
Old Jul 16, 2024 | 04:45 PM
2ToyGuy's Avatar
Try replacing the idler pulley bearing for the power steering belt. IF you can't find the bearing alone, you'll be able to find the pulley with bearing already installed.
Make sure the belt is tensioned correctly. Also according to the FSM, the belt is fully broken in/stretched out after running for 5 minutes. I would let it run 5-10 min, then tension it to th final setting.
Good luck!
Pat☺
Old Jul 16, 2024 | 05:12 PM
2toyguy
thanks for the reply. It only has 25k original miles and i just got it back from the dealer. Had the original timing belt and pump replaced. They said the belt is not original equipment and its too long. Which is odd....maybe it was showing age. Original owner must have had it replaced. Im going to replace and adjust the belt first. See if that fixes the issue.
kamish
May 1, 2018 01:10 PM
Joedills
Nov 1, 2013 07:08 PM
IWish4A69Camaro
Aug 3, 2009 03:01 AM
k_longerbeam
Jul 3, 2009 07:53 AM
