Toyota pick need help badly
Old Aug 3, 2021 | 08:08 AM
Chsse1991's Avatar
Unhappy Toyota pick need help badly
Hello everyone
I live it beautiful Hawaii and I have a 93 pickup 3.0 automatic 4x4 n my problem is truck has a pop I guess u can say it starts it runs but u can hear a pop ever so often n wen u go to drive it if u give a little has it starts to fold over untill full throttle n hold full throttle for a second them picks up rpm n goes until it shift n it struggles till rpm builds up again it was so bad that almost to to accident wen pull out to highway did egr delete a few mouths back n truck was running fine no check engine light cane on n still no check engine light is on
so far I changed cap,rotor,plugs,wires,fuelpump,mas,distributor, overhauled injectors,did a egr delete,redid wires for injectors n distributor all soldered and heat wrapped changed temp sender,temp switch,temp time switch, did all that n still the same don't no what else could be
Old Aug 3, 2021 | 03:40 PM
wallytoo's Avatar
stick to one thread. no need to start a new thread to ask the same question; in the wrong sub-forum as well. run-on sentences aren't helpful when describing the problem. take a breath, clearly describe the problem/symptoms. don't change the "default" text color; the one you chose barely shows up on the monitor.
Old Aug 6, 2021 | 07:56 AM
space-junk's Avatar
have you checked your valve clearances?
Chsse1991
Aug 2, 2021 06:15 AM
La Clon Towing
11
Oct 12, 2016 01:59 PM
owbro
Feb 15, 2013 02:34 PM
hillbllydelux
Feb 1, 2007 09:00 AM
ragrunner
Nov 30, 2006 12:40 PM
