1989 toyota crank no start
Old Jul 1, 2020 | 07:06 PM
jake89's Avatar
I just bought a 1989 toyota pickup with a 22re and manual in it and it will crank and start with starting fluid until it burns it all up. New fuel pump and filter what do you guys think?
Old Jul 1, 2020 | 08:56 PM
millball's Avatar
You got all the intake piping piped up tight???
Old Jul 2, 2020 | 04:27 AM
moto809's Avatar
5 Year Member
Is yours carbureted or fuel injected? It's definitely an issue with fuel getting to the engine if it will run on ether.
Old Jul 2, 2020 | 05:12 PM
jake89's Avatar
Intake piping tight, found a ground on the computer wasnt hooked up when he replaced it. Fixed that ground and now it starts up and fires on all cylenders for a few seconds then only runs on 1 cylender
Old Jul 2, 2020 | 05:21 PM
moto809's Avatar
5 Year Member
I'm not an expert with those systems, but it sounds like your injectors are losing power (or continuity). Could very well have something to do with the bad ground you found. Also, it wouldn't hurt to check your chassis grounds. IIRC there is even a standalone EFI relay in the engine bay fuse block. Relays are cheap, it wouldn't hurt to replace that just to eliminate it as a potential source of your problem.
Old Jul 2, 2020 | 05:45 PM
jake89's Avatar
Well i checked the codes and i get code 23 and 24
Old Jul 2, 2020 | 09:27 PM
jake89's Avatar
It has a new relay, where would the chassis grounds be located at? Thanks for the help i appreciate it
Old Jul 8, 2020 | 05:47 PM
jake89's Avatar
Well i dropped the tank and what do you know its was full of rust. Gonna be replacing the tank and pump and probably most of everything where fuel goes up from there
Nick Marklowitz
Jun 12, 2020 09:16 AM
5.9ford
Dec 6, 2012 05:20 PM
Cliff96SR5
Feb 13, 2008 01:51 PM
tssievert
Mar 13, 2007 02:07 PM
