Still running well, but obvious slow coolant loss and some white smoke on startup. Just the slightest milkyness in the oil when I put her in for teardown.
140.000 miles. about 30 thousand run since I bought it.
This '95 was built with the supposedly 'improved' headgaskets, so it was never eligible for the 3vz headgasket campaign.
Will know more when I get it apart and the heads to the machine shop.
I guess the valve adjustment future is secure, at least. ::
There are 4 or more of every size new, and many good used shims as well.
I just picked up a 3vz 95 runner project with a blown head gasket. 165K on the clock, guy sold it cause he didn't want to deal with it. I never shimmed the valves on my old 93 3vz, ran up 365K on it before I swapped in the 3.4. Maybe that's why I was down a cylinder. No matter, I am in love with the 5vz, probably be putting one in the runner as well.
Reason: forgot actual mileage, fixed it for accuracy
The machinist imparted his wisdom about removal of the block dowels, and the Force was with me.
The ID of the dowels is just right to accept a 1/2 inch tap, and one of my slide hammer rods just happens to be 1/2"x13tpi..... Bing, bam, boom. All out with no pecker tracks or deformation..
I remove the dowels to facilitate block deck cleaning and prep..
Like to be able to lightly drag a fine file over the block deck without having to deal with any obstructions.
The cylinders look great, with original cross-hatch still visible. No discernable ridge, but a little carbon.
Truck only has about 140,000 miles on it, but 25 years and thousands of temperature cycles have taken their toll.
The coolant leak/leaks were just beginning to become apparent. There was never full blown coolant loss to the oil, or overheatiog. Just some rough starting and persistent small coolant loss.
Well, stuff happens, and I'm a Gold Medal winning procrastinator. This truck lay in the garage with the heads off for the last 15 months.
I've got another awesome 4x4 Toyota that runs perfectly well, so no biggie, Eh???
My wife thought that it would lay there until I died.
I've been pecking at it for the last couple weeks and I wrapped it up last sunday. Runs great.
Ishino Gaskets, Aisin timing kit, fan bracket and fan clutch. All new factory ignition parts and plug wires. Mostly new coolant hoses and new drive belts.
cool! i’m a gold medal member myself. my ‘48 dodge sat in front of my house for almost three years with a rod through the block. had a spare motor in the garage, too. when i finally got around to pulling the motor, i had the truck back on the road in just over a month, running as good as ever.
i still have a ‘52 three-quarter ton with fluid drive! my father bought it circa 1985 and i drove it in high school. hasn’t been out of the garage since 1988.
