Troy's 93 pickup (somewhat) build
Old Sep 19, 2013 | 08:39 PM
troydee's Avatar
So I picked this guy up the other day....bone stock 93 4x4 sr5. 5 speed with the 3.slow.
My plan is to do a mild build to make it fairly trail worthy, but first I need to address a few things
Already did the essentials with a new car, oil change, air filter etc....but the whole headgasket issue has me pretty paranoid. I plan on doing a big ass E fan, and the crossover delete ASAP, then the intake silencer delete. Then followed by a small lift...maybe 2.5 or 3 in, new wheels and tires, probably an ez locker or something and maaaaybe a light bar.
As far as squeezing a little bit more power (and MPG) out of the 3vze, does anyone have any other suggestions?
Old Sep 20, 2013 | 05:10 AM
Terrys87's Avatar
Cant help with the 3.0 but both of your trucks look great. Welcome to Yotatech.
Old Oct 8, 2013 | 09:45 PM
troydee's Avatar
so I got all the stuff for the E-fan...and Im using the Volvo 2 speed fan relay with a Ford Taurus fan. Id like to wire it so the low setting can be controlled by the ignition switch, and the high setting can be used on demand, and be left on even when the truck is not. the volvo relay has 2 grounds, one for high and one for low, so i need to find a circuit that would have its ground cut, when the ignition switch is turned off.
I was thinking the ground side of the EFI relay?
any suggestions?
Old Oct 9, 2013 | 04:34 PM
bone collector's Avatar
nice looking truck man. there are a few tips and tricks for the 3.0 to gain some power and mileage. look into the 7mge afm swap, advancing the timing, egr delete. there are a few others. good luck in your build
Jun 1, 2021 01:51 PM
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
toyoda8488
Jul 5, 2015 10:18 PM
