PDA
View Full Version : 3.4 Swaps
Pages : [1] 2 3 4 5 6 7 8
  1. 2WD madness 3.4 swap
  2. 1995 Cruise control
  3. what parts do i need to pair auto trans to 3.4 on 2nd gen
  4. Wear items to change on 3.4?
  5. 1991 4Runner Trans cooler line routing
  6. Oil port orientation on 5VZ-FE rods
  7. 3.4 Swap EVAP Emissions
  8. 3.4 Swap Tach
  9. Best possible donor
  10. Just did 3.4 swap curious about manual swapping
  11. 3.4 swap still viable in 2024?
  12. How did I mess up a thrust washer
  13. Cruise Control 95 3VZ to 03 5VZ
  14. 99 4runner 3.4 does immobilizer matter?
  15. Required parts for 3.4 swap into 1985 pickup
  16. Land Cruiser 90 (Prado) VZJ90 5VZ-FE FSM ?
  17. Anyone in the Escondido-temecula area . . .
  18. 1995 4runner 3vz swap with 1996 t100 5vz wiring help
  19. 4.3 idle issue.
  20. 04 Tacoma 2wd Auto to a 93 4runner 4wd Manual
  21. wiring trouble/ fuel pump
  22. 5vz swap wiring help
  23. 5VZ-FE Block Changes - CA Smog Info Request
  24. 3VZ A/C compressor vs 5VZ A/C compressor - is one better than the other?
  25. Using a JDM donor: Cheeserind's visit to JDM Engines Chicago
  26. Transmission fluid lines to rad getting pinched
  27. 3.4 swap power steering confusion, need help
  28. 22RE to 5VZ-FE ??
  29. 3.4 auto swap wiring help
  30. A/C install into a 1992 Truck that never had it
  31. 94 T-100 3.0 swap 2002 JDM Tacoma 3.4 donor
  32. 94 T-100 3.0 swap 2002 JDM Tacoma 3.4
  33. Shadetree swap in progress
  34. Need feedback and opinions on donor options (Yota1 rebuild vs JDM, etc.)
  35. Where do get a new ECM?
  36. 5 speed and 3.4 swap advice needed
  37. Fuel Pump FC connection and COR
  38. Cross-over pipe
  39. 4runner harness security module
  40. 3.4 swap question
  41. 3.4 swap question
  42. 3.4 Swap Starts BUT Stalls Everytime
  43. Please help- 3.4 swapped questions!
  44. 3.4 exhaust for 95 former 3.0
  45. 3.4 Swap with 4sp. Auto...No 4th Gear???
  46. 3.4 harness Fed vs CA
  47. 3.4 swap no start & no oil pressure on start up!!!
  48. Looking for A340H to 340F 2wd swap physical requirements
  49. Cat “delete” No CEL
  50. 89 3.0 swap to 3.4 (Questions on my Options)
  51. 3.4 swap ignition wiring
  52. 1988 4Runner no N3/IH1 and N5/IH2 found in wiring diagrams
  53. New guy
  54. 3.4 conversion throttle body
  55. Another JDM engine swap
  56. 2001 4runner Donor Questions
  57. Engine mount question
  58. 93 T100 3.4 swap ecu questions
  59. Gremlins in the Electrical
  60. EWD from TIS site?
  61. 3.4 swap question
  62. 3.4 swapped w/ HG
  63. Need a simple answer to 3.4 wiring
  64. 199 7 4WD M/T ECU to 1998 2WD A/T P0773
  65. Best donor?
  66. Akwheeler's 3.4 swap, 96 T100 Donor to 95 4Runner
  67. 99 3.4 (A/T ECU) swap mated to 94 3.0 5sp M/T (CEL issue)
  68. Usdm heads on jdm 3.4
  69. 3.4 Swap intake options
  70. Looking for 90 4Runner IH2 pin out
  71. 3.4 blocks swap can you swap 1mz-fe and 5vz-fe?
  72. 3.4L Swap ECU question
  73. Is there anything speacial i need to know
  74. JDM Engine?
  75. Nick's 3.4/5 Speed Swap
  76. Wiring harness problem
  77. 3.4 swap, mechanical fan
  78. Swapped 1999 5vz into 98 4 runner
  79. Lance's Budget 2nd Gen Build
  80. 89 4Runner with 97 taco m/t 3.4 swap. Runs then dies.
  81. 98 4runner Swap
  82. Ignition Timing Problem
  83. Calling all guru's HELP!
  84. 3.4 wiring
  85. Does anyone have T-100 wiring diagrams?
  86. OBD2 Connection Problem - Help
  87. Yeeeesssss!!!!
  88. Where are referee inspections getting approved in Ca with exhaust on pass side
  89. 3.4l Swap Emissions Problem!!
  90. 3.4 motor swap
  91. AC and Power Steering
  92. Need help
  93. $1000 to anyone who wants to finish my 3.4 swap
  94. 3.4 swap cruise control cable routing?
  95. 3.4L Swap, sparks, cranks, but not running!!
  96. 3.4 Swap Heater Hose Flow Question
  97. 3.4 swap 101.
  98. Bank fired converting to multi fired injectors
  99. Replaced throttle body, now have a very annoying humming noise
  100. Federal ECM in California 4Runner?
  101. Wiring headache
  102. first post and need some help
  103. Questions regarding 3vzfe to 5vzfe swap
  104. Struggle city for the last yard, help requested. 95 A/T 4x4 3.0 to a 3.4 m/t
  105. Finally, 3.4 swapping my 93!
  106. What is this piece on the side of the block?
  107. JDM donor vehicles?
  108. 3.4L swap help
  109. 3.4 swap
  110. ECM location
  111. desprate for 3.4 swap help
  112. Is Toyonly swaps still open?
  113. 1996 t100 donor need wiring diagram
  114. 3.0 swap 3.4
  115. Speedo quit working. Help identifying wires
  116. 3.4 stumped on wiring
  117. looking for info on dual exhaust manifolds on a JDM motor
  118. 3.4 swap / coolant temp not working
  119. 1990 4 Runner 3.0 to 3.4 swap questions
  120. 5Vzfe Swap with A340H
  121. First gen pickup, what efi tank bolts in?
  122. 3.4 Swap No Start
  123. 1995 Toyota 3.4 swap need help
  124. 3.4 Swap connector questions
  125. 3.4 engine height on 3.0 mounts in rwd xtra cab Fram
  126. 99 4 runner with 22re, swap in a 3.4l help
  127. Mounting 3.4 ecu?
  128. 3.4 swap occasional no crank no start
  129. Circuit Opening Relay and Fuel Pump
  130. Questions about starting a swap(noob)
  131. 2nd gen 5vz swap transmission Q’s
  132. 1992 Toyota Truck 3.4 Swap
  133. 1999 engine swap
  134. Where to buy ecu plugs for 1998 3.4 manual ecm
  135. 3.4 swap stumped
  136. Dash plug diagrams
  137. Turbo 3.4 help
  138. 3.4 close but no cigar
  139. 3.4 swap
  140. 88 motorhome 22re to 5vz
  141. Need help finishing my 3.4 swap
  142. Vacuum and wiring help
  143. 1996 3.4 igniter pinout or picture
  144. Possible swap header to use
  145. OBD2 port issue on swap
  146. T-100 3.4l swap donor question
  147. Everything except engine?
  148. 3.4 5VZ wiring differences, 2000 vs 2002
  149. I need 3.4 swap help!
  150. Final step
  151. hoist how to...first engine pull
  152. 3.0 balencer on 3.4
  153. Lots of coes from my 95 3.4 swap
  154. New pickup with 3.4 swap clutch question
  155. 3.4 Power steering Banjo replacement?
  156. sr5 tach wiring
  157. 5VZ and auto into F-Toy buggy
  158. Seriously need help with my runner , I'm completly stumped
  159. BackCountry's 92 Runner build
  160. Which oil pressure switch?
  161. How to identify Fed and Cali 3.4
  162. Some newb questions as I start my swap
  163. Hesitates under load until WOT
  164. 22r Sunrader to 3.4 swap questons
  165. 3.4 headers
  166. 3.4 swap crank no fire, popping and backfiring.
  167. 3.4 swap, running poorly
  168. 3.4 donor complete harness swap to 88 T4R 22re
  169. Wiring Diagram 94 3.0 AT to 99 3.4 MT
  170. a SPEEDOMETER would be nice
  171. 3vz-5vz electrical help me!
  172. Wiring help for 1988 4Runner
  173. 3.0 to 3.4 swap done, 5 speed swap? Need help
  174. 99 4runner 3.4 Plug identification.
  175. Automatic Donor, Manual Truck. Can It Work?
  176. Best How-To on the 5VZFE Swap?
  177. 88 4Runner swap-Indiana help
  178. 1rst gen super charger
  179. Help! JDM 3.4 Swap
  180. 5vzfe swap
  181. Engine swaps
  182. 1992 3.0 to 1998 3.4 swap wiring help! P0100 p0115 p0505
  183. 3.0 to 3.4 swap WIRING HELP
  184. harness from 1993 3.0 to engine
  185. P0705 After Swap
  186. Need help
  187. High RPM?
  188. 3.4 Swap Help
  189. Help! 3.4 Swap Issues
  190. Looking for some help..
  191. Which radiator for 84-89 4Runner/Truck 3.4 Swap?
  192. Auto 3.4 swap to manual 3.4 tacoma
  193. P0500 Code - Vehicle Speed Sensor
  194. Wrong ATF in P/S System - Damage?
  195. Help! No Crank after swap!
  196. Wiring nightmare
  197. 3.0 Motor Mount 3.4 A/C Bracket Compatibility
  198. Correct fuse for AM2
  199. 22re to 5vz wiring conversation
  200. 3.4 swap 884runner
  201. 3.4 swap 2wd 4 runner engine to 4wd truck
  202. Plugs with the 02 Sensor wiring
  203. 3.4 swap wiring diagram error ?
  204. Transfercase crossmember-Engine placement
  205. California BAR Update
  206. looking for a diagram to help explain how to install a red ke switch
  207. 3.4 Swap, Red 1990 SR5
  208. 2001 toyota 4runner AT 2wd 3.4 swap into a 89 toyota 4x4 pickup 3.0 manual transmissi
  209. 3.4l wiring confusion
  210. 3.4 Swap on a 1994 Toyota Pickup
  211. 3.4 swap.. BIG problem
  212. Anyone ever had this problem?
  213. is it possible to fry the trans ecu and accuator at the same time?
  214. 22 lifers per 100km
  215. 3.4 swap
  216. ECM repair
  217. dipstick plug removal?
  218. 3.4 swap electrical and parts
  219. engine swaps
  220. 3.4 swap and tacoma vehicle speed sensor
  221. 3.4 In Second Gen Alternator Clearance ?
  222. Toyota 3.4 swap which may to use
  223. Fuel Rail flip photos
  224. 3.0 Charcoal Canister help
  225. 1994 TOYOTA-4-RUNNER-Engine Swap
  226. 3.4 swap with no power
  227. ideas for breaking crankshaft pulley bolt on 3.4 sitting outside of truck?
  228. Runs great... for 5 seconds
  229. 1989 4Runner 3.0 t0 3.4 swap
  230. I'm having trouble viewing pictues
  231. 3.4 swap hood clearance
  232. 3.4L with original auto trans.
  233. Cut sensors..?
  234. Toy Only Swap plug and play
  235. Comprehensive Tool Check List
  236. 3.4 swap
  237. Ecu question
  238. 1988 22 re manual to 3.4
  239. The famous 2nd gen 3.4 swap
  240. Starting issues after swap
  241. Busted 3.4 to new 3.4 swap
  242. Swap help
  243. 1995 4runner with freshly Swapped 3.4 Has Engine Tick
  244. '93 T100 3.0 to '97 3.4 Swap
  245. 1993 Pickup 3.0 manual to 1998/1999 3.4 manual
  246. t100 Trans and transfer case
  247. The Gryphon Runner Swap
  248. So i think i found a donor can please bare with a newb here
  249. Harness conversion for slightly mismatched ECU
  250. ORS or Toyonly swaps conversion harness?
