Looking for some help..
Old May 7, 2018 | 04:45 PM
Ratical's Avatar
I just completed a 3.4 swap, 1994 4runner original 2wd now mounted on a 1988 rn pickup chassis still 2wd. The doner was a 2003 Tacoma prerunner 2wd. I swapped motor and trans from Tacoma engine harness and ecm. I did conversion wiring. Everything is great except for a single mil. P0705 transmission range indicator malfunction. (Prndl switch sees more than one input at one time.).
So faults cleared start in park = no faults
Start in netural = no faults
Place in any other gear = fault
netural has to signal to ecu, so park is the input staying on.. tracing ewd 4wd has "park" lamp in cm pre runner does not so circut should be open but I measure 12 volts on pin into ecm. I've tried 3 different ecms so i don't think that's it. I tried several wiring changes.if I leave gear selector wires it will eventually give a fault for not seeing a signal but seeing speed sensor.
Anyone else ran into this. Am I missing something small? Is there a way around. Any help appreciated..
Mason Dixon
Jan 24, 2013 12:53 PM
flynhighaf23
Jan 26, 2008 04:01 PM
Millertime
Jan 20, 2008 03:20 AM
elks
Sep 29, 2007 11:58 PM
