a SPEEDOMETER would be nice
Old Oct 2, 2018 | 08:20 PM
-burzum-'s Avatar
Just finished up my 3.4 swap and all is well with no codes. BUT I cant seem to get the speedo to read (it worked before the swap with same speedo and VSS). I have checked the VSS in the tail housing and it gives a pulsed 12v signal and the three wires are hooked up as follows
VSS connector IH2
B-O------------> B-O (pin8)
G-L ------------> G-L (pin 13)
G-R -----------> G-R (pin19)
I have also hooked up the G-L wire to the ECU
Anything im missing here?
Old Oct 4, 2018 | 07:00 PM
-burzum-'s Avatar
Fixed, needle got on the wrong side of its stop. must have happened when i did the tach resistor
Old Oct 4, 2018 | 07:38 PM
old87yota's Avatar
I am glad you got it fixed!
Thanks for posting the fix for future reference!
FuelforWar
Nov 13, 2013 09:21 PM
toyospearo
Mar 5, 2013 06:14 AM
