PDA
View Full Version : 3.4 Swaps
Pages : 1 2 3 4 5 [6] 7 8
  1. R12 or R134A?
  2. 4WD light
  3. dead cylinder
  4. 3.0-->3.4 wiring assistance
  5. vacuum/coolant line diagram
  6. a/c clutch changeover
  7. A/C help!
  8. A/C and Tach problems
  9. should I swap, sorting my options
  10. first 3.4 swap need help plz.
  11. 3.4 swap wiring diagram
  12. How many passed CA referee?
  13. daily driver 3.4 swap new to the EFI swap world.
  14. Dtc p0141
  15. 1995.5 - 2004 Tacoma A/T vs M/T ECU pinouts
  16. Vss
  17. 3.4 ac wiring
  18. Sputtering around 3 grand sometimes
  19. anyone know about these two circuits
  20. Rust question
  21. clutches and flywheel help needed
  22. 3.4 swap crossover pipe.
  23. What Trans?
  24. Passing smog with the swap
  25. Air intake temp sensor?
  26. I need a EWD for a 95.5 manual .....got it? or TIS acccess??
  27. 28 pin plug
  28. Aftermarket hood for the 3.4 swap. Who’s looking?
  29. Reverse light switch
  30. Trouble shooting help - kinda swap related
  31. VSS issues
  32. anyone want a FREE supercharger
  33. 3.4 off to a rough start need advice
  34. No power checked fuses
  35. Running issue
  36. what is the E2 pin on the ECU?
  37. 3.4 Clutch w/ 3.0 Flywheel
  38. 3.4 motor to 3.0 auto tranny - truth or myth?
  39. 84 22RE to 5vz
  40. Yup, another 3.4 Swap
  41. No temp reading
  42. o2 sensor wiring... can't find them...
  43. 3.4 motor plate
  44. Fuel pressures
  45. coolant bleeder
  46. charging system diagram
  47. 3.0 to 3.4 COR SWAP HOWTO:
  48. No Check Engine light or Codes
  49. 97 3.4 swapped, running issue
  50. 1990 3.0 to 1999 3.4 questions
  51. 3.4 swap to 94 pickup
  52. repinning auto harness to manual. Can it be done?
  53. Donor auto my truck manual what do I do?
  54. CatConv. ?
  55. 3.4 5spd Computer
  56. Tranny adaptor
  57. Clutch issues
  58. Think I got in over my head: 3.4 swap help needed
  59. Anyone have any starter/battery wiring pics
  60. What year did the 3.4 change? (A/F)
  61. Starting slow 3.4 swap
  62. 2RZ to 5VZ? What's involved?
  63. Starting my 3.4 engine swap
  64. Repinning What's The Trick
  65. More 3.4 questions
  66. no info on TIS for 89 4runner??????
  67. Which harnes to use?
  68. Ecu question... Stumped
  69. 5vzfe swap into 89 Toy 4x4
  70. 5vzfe swap into 89 Toy 4x4
  71. Can I use 3.0 P/S & Alt on a 3.4?
  72. 3.4 swap almost complete, just a few loose ends. Help?
  73. SoCal referral
  74. SoCal Help p
  75. Finally getting rid of the 3.slow
  76. Seperate Engine and Transmission???
  77. Which way did you route your M.Trans wiring?
  78. O2 Sensors
  79. 3.4 Automatic swap ????
  80. Will these headers fit?
  81. trans just will not line up
  82. Running Sluggish after engine swap: Connection right?
  83. 3.4 swap help
  84. 3.4 auto to manual swap info??
  85. 89 pickup 3.0 to 3.4
  86. 90 4runner 5vz swap. Need help with last couple wires!!
  87. Wiring harness differences between man and auto
  88. 3.4 in 3rd gen 2.7l 4Runner?
  89. What would you do?
  90. 1990 2dr 4runner swap started today
  91. '88 3VZE 5-speed wiring diagram help.
  92. Identify A/C Amp
  93. swap costs and parts needed
  94. EVAP canister
  95. What fuel mileage are you getting with your 3.4 swap?
  96. help to identify plugs(wiring)
  97. California OBD II Catalytic Converter Question
  98. 1989 EWD's Electrical Wiring Diagrams
  99. 3.4 $2000 Budget Swap
  100. another successful 3.4 swap done!
  101. 3.0 and 3.4 flywheel
  102. Another 3.4 lives and breathes
  103. Should I go for this? transmission from 3.4 Donor truck
  104. Using stock 3.0L Auto w/ the 3.4L ...Yes!
  105. 3.4 Auto ECM to 5 speed swap
  106. 3.4 Swap Issues
  107. Soon to join the ranks...
  108. Supercharged 3.4 into '88 4Runner 3.0 5 Speed
  109. locating gauges post-swap
  110. T/case adapter plate question
  111. 91 Runner Getting The 01 Taco 5vz-FE COMPLETE SWAP
  112. 88 4Runner 3.4 swap w/auto to Marlin 4.7 T-case
  113. TIS Wiring Diagrams
  114. 3.4 Alive in SD!!!
  115. Quick dirty way to find your wiring connections
  116. 3.4 Headers
  117. 3.4 Wiring Helper Thread
  118. Wanted: Stock 2001 or later manifolds and crossover
  119. Nearly died from my 3.4 cutting out
  120. Wiring 92 truck man 4x4 -> 98 4runner man 4x4
  121. Over heating/operating temps
  122. ADD 4 wheel Drive
  123. clutch kit
  124. 3.0 to 3.4 ?'s
  125. Almost Running
  126. Wiring ID Question
  127. 3.4Auto 4Runner swapped into a 3.0Manual Pickup dream machine>Issues
  128. Best junk yard find for my 3.4 swap
  129. Another swap but supercharged.
  130. Help am I in trouble with the dip stick
  131. Auto trans
  132. 22re to 5vz
  133. 95-97 MAF on 99-04 Engine?
  134. Reman h2o pump. FIPG or use the paper one
  135. 3.4L on an engine stand
  136. 3.4/4.0?
  137. wanted ( crossover pipe )
  138. Which windage tray should I use?
  139. a-340-e
  140. Fuel Line
  141. 3.4 swap getting started
  142. 5vz 3.4 v6 wiring harness
  143. Anyone interested in a 3.4 sticker for the tailgate?
  144. 3.4 Swap- Oil pressure switch
  145. Yet another 3.4 swap into a 92 ex cab pickup
  146. 3.4L swap Auto ECT question
  147. Wiring Question
  148. found donor but is it worth the $
  149. is there a difference 97 vs 99 ecu
  150. Cali Engine Swap legal swaps
  151. Harness and ECU compatability
  152. Few questions about picking the right 3.4L
  153. Anyone actually installed the 3.4 Downey headers in a swap?
  154. What hood scoop & where to cut?
  155. 1991 4runner disel swap
  156. 2wd or 4wd engine harness & ECU
  157. Dipstick drill guide needed
  158. ?? about relocating dip stick
  159. Looking to do a swap
  160. has anyone figured out the ac yet
  161. 2003 5vz
  162. Im going to school for toyota, wanna do the 3.4 swap, i have access to TIS, need help
  163. 1999 3.4 into 1993 X-Cab
  164. started 3.4l conversion in my 1993 4runner
  165. Want to start 3.4 swap on 84 4runner
  166. Question- 3.0 to 3.4L
  167. what radiator do you use with the 3.4 in 84 4runner
  168. Found a motor, but i have some ?'s
  169. Anyone know how to Contact Mike From ORS?
  170. fairly interesting mod for you supercharged guys
  171. Swap issues- intake leak/idle issue
  172. Possible Camshaft Sensor problem
  173. 3.4 runs rich and bogs
  174. two questions regarding 2001 motor
  175. Anyone Need Diagrams
  176. Evap/return line routing... major gas leak
  177. newbie here got the 3.4 just have ?s
  178. Vacuum lines and add issues
  179. T100 Oil pan Question
  180. For those of you looking for a 3.4
  181. 3.4 swap not starting.
  182. 3.4 swap milestone
  183. Help with wiring
  184. hey guys need a ton of help! 3.0L lol 2
  185. what spare trail parts for 3.4
  186. Ignitor test?
  187. OBD II issue
  188. maybe useful parts diagram for 96+ runners
  189. Exhaust Manifold ????????
  190. Where to get a 5vzfe?
  191. Has anyone tried running a 3.4 with a 3.0 ECU?
  192. Infil's 3.4 swap!
  193. swapping harnesses on motor
  194. 3.4 into a 77 FJ-40/ Help
  195. It had officially began, 3.0 auto to 3.4 manual in 92 ex-cab
  196. Finally!!!!! found a donor!!!
  197. OBD2 Scanner wont finish reading codes
  198. 3.0 to 3.4 engine removal
  199. Got a DS 3.4 mount layin around?
  200. 3.4 Swapped...but oil pressure gauge making me NERVOUS!...& some 3.4 teaser pics.
  201. What is the name of the switch on the front diff?
  202. hopefully startin my 22re/5fze swap soon
  203. 3.4 swap begins
  204. Flywheel ???
  205. 2002 3.4 auto into a 1991 3.0 manual
  206. Tach problems...22ret to 5VZ
  207. Pre-swap homework
  208. 3.4 wiring service in sc,nc,or ga
  209. 22ret t0 3.4 swap help
  210. EVAP questions
  211. gearing question
  212. electronic cruise control issius
  213. 2000 engine troubles
  214. Anybody NOT relocate the battery?
  215. O2 Sensor Questions
  216. help needed
  217. Anybody still build wiring harnesses?
  218. wire for the starter
  219. Power steering line...what size is the banjo bolt?
  220. help can't find my starter relay
  221. Circuit opening relay confusion
  222. 2000 A/T motor w/97 M/T wiring
  223. Where to find plugs on TIS
  224. Bellhousing question
  225. 3.4 w/supercharger into 89 4 runner
  226. harness and ecu
  227. Fuel Line Question
  228. Header question for 3.4 swap
  229. 22re (1986) to 3.4...notes
  230. Stock auto trans wiring
  231. wire harness?
  232. Final preperations
  233. removing pins from the connetors
  234. Question on 3.4 swap?
  235. 3.4 swappers who did there own wiring
  236. someone help this newb!
  237. 3.4L Engine swap
  238. 2000 taco MT ECU
  239. 3.4 cross over pipe help
  240. Simple battery tray
  241. 3.4 accessory mounting brackets
  242. 3.4 swap connector help please
  243. Is a '98 just as "good" as an '01?
  244. What did u plug your old dipstick hole with??
  245. FEELER*3.4 conversion harness *FEELER
  246. Swap runs perfect w/ECU unpugged!
  247. 3.4l!!!!
  248. how do I identify what year/run from the numbers on the ecu???
  249. Troubleshooting 3.4 Swaps
  250. 3.4 Exhaust temps, Whats normal?
