3.4/4.0?
Old Feb 23, 2010 | 05:51 PM
Bigblock's Avatar
3.4/4.0?
Just brain storming here.Does anyone know if a 4.0(1grfe)crankshaft will fit in a 3.4(5vzfe) block?That would make a nice Stroker 3.4/4.0!Bore spacing should not be a problem because they are almost the same.Dont know where else to find this info.
Bigblock
Old Feb 23, 2010 | 05:53 PM
Bigblock's Avatar
I dont know about the deck height either.
Old Feb 23, 2010 | 06:56 PM
yodathespian87's Avatar
Wow. I don't know. I'm interested in hearing if it works.
Old Feb 23, 2010 | 09:19 PM
RobD's Avatar
I'm going to suggest no, that it won't fit.
Odds are the journals are different sizes and even if the bore spacing is "close", a few thousandths of an inch will make all the difference.
Only way you're going to know for sure, though, is to try.
Old Feb 24, 2010 | 02:38 PM
Bigblock's Avatar
They have the same bearings.I had no luck on the phone today.None in junk yards.No after market cranks.Nobody knows anything.Anyone have an FSM for the 4.0?
Bigblock
