3.0-->3.4 wiring assistance
Old Jul 19, 2010 | 09:54 AM
DWEINBERG01's Avatar
I am in the middle of my 3.4 swap. I am interested in doing the wiring harness adaptation myself. My question is , I know that I need the 2 plugs off of the 3.0 wiring harness that go under the drivers side dash. What is the best way to determine what wires need to be lengthed and what wires need to be adapted to make the 3.4 motor work with the rest of the truck. Is it just the wires from those two plugs or am i gonna have to remove all of the protective covering from the harness and splice into it in some weird area. I have the wiring diagrams, just wondering what systems need to be adapted.
Also, is it better to do the harness while the engine and trans are out of the truck or should i install everything and do the harness in the truck?
1997 3.4/auto going into a 1995 used to be 3.0/auto. Thanks.
Old Jul 19, 2010 | 09:56 AM
dropzone's Avatar
Fossilized
FYI: I am editing your thread title: HOLY CRAP that's alot of wires. is one that per the rules fits the criteria 'ambiguous, could lead to deletion with out notice"
Old Jul 19, 2010 | 10:00 AM
Thanks. I appreciate that.
dropzone's Avatar
Fossilized
no prob
Good luck, hope you find the info you need
Old Jul 19, 2010 | 11:12 AM
dntsdad's Avatar
To figure out what you need this is what I did. Go through every wire using a EWD or FSM and figure out what one in your truck you are going to need. You will need essentials like tach, water temp, oil pressure, etc. Those are common on both trucks. Cap off everything that is not common for both truck like the AFM on the 3.0 etc.
I didnt use the cruise and my AC doesnt work so I didnt use those.
Get the motor in and run the harness from the 3.4 into the kick panel area THEN hook everything up.
Old Jul 19, 2010 | 12:10 PM
Thanks
My wife will be happy to hear this as she is always askin ," When are you gonna get this outta the garage?
Old Jul 19, 2010 | 12:20 PM
dntsdad's Avatar
awww women...................if they only understood.
Old Jul 20, 2010 | 08:21 AM
hamish_18's Avatar
ROFL. It was my dad in my case as I had my runner and both motors on stands in his shop. Seriously I think I have used his shop more than he has LOL. And x2 on what dntsdad said. It is a lot easier if you break down each component wire by wire. Don't look at the whole harness as a whole. Thats what got me frustrated.
sandyota
Feb 4, 2021 11:16 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
93toyoguy
Aug 2, 2015 07:41 PM
94whiterunner
Jul 12, 2015 07:15 PM
