4WD light
Old Jul 20, 2010 | 11:13 AM
Dewbro91's Avatar
4WD light
I know this isn't a huge deal but I would like the dash light to come on when its in 4wd. Its pretty obvious it is but I would like most everything that worked before to still work. Does anyone know how to hook this up?
Old Jul 20, 2010 | 11:50 AM
hamish_18's Avatar
with A.D.D or not? and I think this will be what you need:
http://www.ncttora.com/fsm/1990-1995...emci/4wdmt.pdf
Old Jul 20, 2010 | 05:35 PM
UKrunner's Avatar
You will need the switch in the diff, do you have that?
Old Jul 20, 2010 | 05:47 PM
dntsdad's Avatar
I dont have a switch in the diff anymore. I used the one off the transfer case I think.
Old Jul 20, 2010 | 06:55 PM
UKrunner's Avatar
Hmm, mine goes from fuse to bulb to transfer switch to switch on the diff to ground.
Old Jul 20, 2010 | 07:58 PM
Dewbro91's Avatar
Yeah I do have the switch in there. I tried messing with it earlier today and i couldn't figure it out.. hmm
Old Jul 21, 2010 | 07:31 AM
hamish_18's Avatar
I tried getting my 4wd to even engage with the A.D.D. and it never worked right. I had my old IFS frontend from my truck when I SAS'd it, when I put gears in I used that frontend, so now I have hubs, and no A.D.D. Much cleaner, and I don't have to worry about getting a cut vacuum line, or cut wire to keep me over night somewhere because I lost my 4wd.
Old Jul 21, 2010 | 07:57 AM
dntsdad's Avatar
Shouldnt be that hard. One side of your bulb has power from ignition, the other gets ground from the transfer case switch. Check for power at the bulb by pressing your meter lead against the trace leading to the bulb on the back of the instrument cluster, see if it ground when you shift to 4x4. If so you have a bad bulb, if not start tracing that wire back to find where it not getting a connection.
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
Athansinis
Jul 27, 2015 08:38 AM
ripp96
Jul 25, 2015 02:32 PM
TokyoD23
Jul 12, 2015 06:01 AM
