95-97 MAF on 99-04 Engine?
Old Feb 28, 2010 | 02:42 PM
TOYJOETA's Avatar
I'm swaping a 2002 3.4 into my 85, and already have a MAF out of an older 4Runner, can I use that MAF on the newer engine?
Old Feb 28, 2010 | 02:48 PM
Elton's Avatar
if you can figure out which wires go where be easier to put in the less bulky 99 up maf
Old Mar 1, 2010 | 05:22 AM
TOYJOETA's Avatar
Wiring isn't a problem, They both have the same connector IIRC, it would just be cheaper sense I've already got the one, and it's easier to make an intake cause all I have to do is get some silicone adapters and tubing.
Old Mar 1, 2010 | 03:04 PM
dntsdad's Avatar
If it was me, I would get everything working with all the "right" components and then begin to switch things out for whatever your reasons are. that way if you need to troubleshoot, you dont have to guess if the issue is a mismatched sensor.
Old Mar 1, 2010 | 03:13 PM
TOYJOETA's Avatar
Very true, i'd rather use the correct one also, I'm just being a cheap ass, and would like to keep the $100 plus bucks in my pocket and use the one I've already got on hand if it will work.
Old Mar 1, 2010 | 03:24 PM
Elton's Avatar
100 dollars for a maf ? i paid like 20 for good one off ebay
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
Sleaker
Aug 26, 2020 06:03 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
