Fuel Line
Old Feb 18, 2010 | 08:06 AM
dem0nk1d's Avatar
Fuel Line
I've seen talk about the fuel line flip. But does anyone make a custom fuel line that connects near the frame rail, where the upper fuel line connects? And has anyone tried using the 3.4 fuel line? I'm not sure if it's in the same spot.
Old Feb 18, 2010 | 11:41 AM
yodathespian87's Avatar
I used the stock 3.4 fuel line. It's on the back of the rail. you remove the bolt witht eh 2 metal washers, flip the line and bolt it back up. Works great tucked out of the way and threads to the existing 3.0 old fuel supply line.
https://www.yotatech.com/forums/f160...51/index2.html
https://www.yotatech.com/forums/f160...runner-180613/
Old Feb 18, 2010 | 04:48 PM
dntsdad's Avatar
x2 worked perfect until I had to use the stock crossover. then its in the way.
I had to bend a new one from the filter on TOP of the frame to keep it away from the crossover so i dont explode.
Old Feb 19, 2010 | 04:15 AM
Wavephf's Avatar
i did the fuel line swap as well, no problems.
http://s874.photobucket.com/albums/ab303/wavephf/
Old Feb 21, 2010 | 08:53 AM
skunkwhat's Avatar
stock 3.4 line flipped on the rail worked for me, just adjusted as needed for clearance.
pyramid
Jul 30, 2015 10:05 AM
Poppie51
Jul 23, 2015 05:03 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Poppie51
Jul 16, 2015 06:16 PM
Fundy Rider
Jul 16, 2015 01:35 AM
