PDA
View Full Version : 3.4 Swaps
Pages : 1 2 3 4 5 6 7 [8]
  1. So it begins...94 IFS 3.0 auto to a 3.4 SAS auto
  2. Was it worth it?
  3. Lysmachia's CAB/Engine Swap for Tippy
  4. Rayl82's 3.4 swap
  5. adding a/c from your 3.4 donor vehicle?
  6. 3.4l swap questions
  7. 3.4 ecu connectors
  8. Time to swap to a 3.4
  9. Which ECU ECM? 2x4 or 4x4
  10. Hood option's for a 3.4 swap.
  11. 3.4 swap question
  12. 5VZ-FE Engine Swap information
  13. Trying to understand a few tyings:
  14. been searching and reading 3.0 -3.4 swaps
  15. 3.0 clutch/flywheel- 3.4
  16. crosspost for those wanting a 3.4L to swap
  17. 5VZFE fan housing and pulleys
  18. 3.4 swap info
  19. Elvota's 3.4 swap
  20. FYI: 5VZ-FE V6 works fine with the auto A340H
  21. Splicing shielded wires
  22. 3.4 swap runs horrible
  23. Allllrighty, here we go again. 3.4 swap?
  24. 22r to 5vz swap
  25. If you 3.4 swapped again...
  26. 3.4 swap section missing
  27. 3.4 l vs. 3.0 l
  28. Modified 3.0 versus 3.4 swap.
  29. 3.4 oil pressure not reading??? Running hot
  30. might be venturing into a 3.4 swap
  31. Project: 85 5VZ-FE 4Runner
  32. 3.4 swap help needed
  33. 3.4l auto swap guys
  34. yotaman's 2nd Gen 3.4 swap!
  35. Another 3.4 Swap
  36. 3.4 Conversion Throttle issues
  37. Finally venturing into my 3.4 swap (dial up warning)
  38. 3.4 5vzfe vacum hose
  39. 3.4 swap started
  40. My '93 P/U 3.4L swap project
  41. 3.0 to 3.4 swap speed sensor question?
  42. 93 4Runner 3.0 - 3.4 conversion w/ auto
  43. Swaped 3.slow for 3.4L NICE!
