View Full Version : 3.4 Swaps
Pages :
7]
- 3.4 swap into 1990 P/U - ECU/Tranny question
- Not sure where this should go but I need help
- 3.4 swap in action. I gotz issues though
- A340H 3.4 Swap #2
- TMZ runaround
- 3.4 oil pressure
- Swap shops
- 3.4 swap bogs like crazy
- 3.4 lift?
- swapping in motor from auto transmission
- 3.4 to 86 swap help
- '04 Taco engine in a '97 4runner?
- PO440 Question
- Hoping someone can clear up transfer case mods for automatic 3.4 into 2nd gen 4runner
- Could use a helping hand, 3.4 swap, Tucson area..
- Has anyone actually used a 3.4 AC Amplifier?
- About ready to start a 3.4 Swap
- Idle issues
- Help with 3.4 mod in 92 4x4 truck
- 3.4 vaccum line routing help
- How does the 3.4L handle high revs?
- 1st Gen 4Runner 3.4L Swap
- 3.4 auto swap done.. and cheap! Thanks Yotaetech!
- 3.4 missing part.. engine to trans peice
- Lots of great info on this page!!
- It's Dead :(
- newb 3.4 wiring question
- 49 State donor for Ca build
- Why are people drilling out dipstick guides?
- 3.4 with auto swap help.
- 22r (not RE)-3.4 fuel delivery questions
- Few questions that I cant find answers to about possible swap
- 3.4 swap Question
- 3.4 swap wiring question
- 3.4 igniter and evap system
- techinfo had NOTHING for my 88 4Runner
- 3.4 wont run
- TMZ update
- need advice should I buy this 3.4 for a swap
- Where is TMZ?
- ORS closed where can I get a harness and the rest of the swap stuff?
- Do you think this ECU/harness will work for me?
- 3.0 to 3.4 swap
- Got a motor, need engine harness and ECU....
- schneiders 3.4 swap
- 3.4 swap questions ecu
- Aussie 5vz 340h auto swap. Need wiring help please.
- HELP! 3.4 starts then dies!!!
- Black box build
- 3.0 to 3.4 HELP!!!!!!!!!!!!!!
- 3.0 to 3.4 swap
- 3.4L swap hood scoop
- 3.4 into 85' motor mounts?
- O2 sensor, red/white wire trouble.
- 3.4L swap into 2nd gen 4runner
- 3.4 liter Build Runs rich Codes P0120, P0171, P0505
- 3.4 ?
- Bearing clearances on 5vzfe
- Getting Ready to do a 3.4 swap - Need Help
- 3.4 Swap - hydrolocked first motor, swapped in new motor, will NOT start! HELP!
- Question about 3.4 auto conversion into a 91 4runner
- 3.4 Auto swap into 91 4runner
- 91' w/ 3.4, starting issues...please help!!
- teach me about "drive-by wire" specifics
- 91' pu w/ 3.4L starter help???
- VACUUM Cruise Control on 3.4?????
- fuel line pics
- Which motor and tranny do I need?
- 2001 5vz-fe Swap into a 93 4Runner
- What are the bare minimum wires that have to be connected?
- s.c. 3.4
- swapping auto motor into manual truck
- 22r to 3.4 swap question.
- engine swap question
- found these in yunkyard, will they work together?
- Post swap rattle (Engine related)
- ECU looking for a security device
- quick ecu question
- Engine Bay Setup?
- Power Steering, Clutch, & Fuel lines, etc..
- Need wiring diagrams
- Engine importers
- dipstick question
- 3.4/3.0 pulley question
- 3.0 to 3.4 flywheel query
- 3.4 Harness
- 3.4 help asap
- What ecm will work with a 96?
- Whats the fastest you have gone?
- 3.0 to 3.4 prerunner swap
- 22re to 3.4l swap
- seattle area- interested in swap
- 3.4 wiring harness compatibility
- 1st timer 3.4 swap. i will have questions!!
- 3.4 factory intake or aftermarket one?
- used motor 3.4 compression ??
- ADD Issue
- Wiring harness question
- Another "yotaman" 3.4 swap!
- 3.4 auto => maual trans???
- 3.4 Swap Wiring Questions/ Issues
- 3.4 swap
- 3.4 Swap Shop
- 3.0L to 3.4L 94 4WD auto pre-plunge questions/homework...
- 3.4L Swap w/2nd TRD supercharger
- Booked my appoint. for the swap!
- 3.4 tranny swap questions
- Socal 3.0 to 3.4 swap..
- clutch install question
- 3.4 Swap on 2nd Generation
- ORS 3.4 swap instructions
- Running issues after swap
- Fuel pump change as part of swap
- 3.4l radiator ?
- 3.4l oil pickup tube?
- 96 3.4 into 95 4Runner swap schematics here
- 22r to 3.4l motor mounts
- 3.4 Starts then stalls
- 1991 manual trans, manual hub, v6, ext cab 4x4
- 3.4 Drive train
- Anyone in Carbondale, Co due a 3.4 swap?
- 94 4runner 3.0v6 to 3400 V6
- 3.0 to 3.4 swap hard $ cost?
- 2000 Taco 5sp 3.4l into a SAS'ed 1995 PU 5sp 3.0l
- Cruise Control
- any help for my 83 truck?
- 3.4 swap driveshafts?
- Conversion Wiring
- Evap Swap
- 3.4 Swap into an 89 4x4 truck in progress! Some questions......
- fuel pump voltage
- IH2 wiring confusion *PLEASE HELP*
- 3.4 Swap Information links
- 3.4 swap in the style of Breknraj
- EWD request
- misfire
- FIRST TIME TOY OWNER's 3.4 SWAP THREAD
- 22re to 3.4 radiator
- swapin a 22r for newer one(help!!)
- Shifting issues Post 3.4 swap
- 3.4 swap completed, engine wont stay running?
- Electrical question on 3.0 to 3.4 swap????
- $5000 on the hard 6 - An auto/3.4 swap twice
- oil pressure
- ECM connector help
- 98 auto 3.4 into 89 5spd 3.0?
- Buying a complete 3.4 + wiring and ecu right now - quick help
- 3.4 Swap Questions/Prefrences
- 3.4 Swap Oil Pan ?
- Help! I may have screwed myself?!?!?
- wire diagrams
- 2wd 3.4 swap complete
- What else?
- Help with 5VZ block serial number
- Anyone have pics of splicing dash wireing?
- Horrendous squeal, please help.
- Hoping to find a kind and knowing swapper in Tucson on short notice
- evap
- Starting 3.4 Swap - Some Questions
- ors harness
- another 3.4 write up
- ecu questions
- Help T.I.S. website
- 3.0 to 3.4 swap WIRING!!
- Link - 3.4, auto & tc possible sale (not mine)
- 3.4L clarification
- 3.4 No. 2 O2 Sensor (1 Wire)
- price paid/where for a 3.4 swap
- Jumping in to the 3.0/3.4 swap
- 3.4 swap / 4x2 or 4x4?
- 1990 runner and question...
- EVAP Canister VSV question
- DOME fuse keeps poping after swap.
- advice in finding the ideal 3.4
- What up with TIS???
- new 3.4 swap t100 question.
- OBD2 scanner
- Pics of my 3.4L waiting to be installed...
- another *inexpensive* 3.4 swap
- ok, i've looked into all swaps
- 3.4 "long block" use parts from my 3.0
- Where to purchase. Spark-plug cap retainer?
- 3.4 sputter sputter pop sputter
- 3.4 ecu
- 3.0 swap to 3.4
- A/c Help!
- 3.4 swapped running rough
- 4x4 ECU in a 2x 3.4 conversion
- It's ALIVE!
- Need Help on 3.4L swap.
- 3.4 swap and a 5 speed swap!!!
- 3.4 wiring hell
- 98 5spd 4wd ecu/harness wanted, buy or trade
- 3.4 swap park/neutral switch code
- Found a 3.4L!! Finally doing a swap!
- WTF Clutch dont fit--lil help guys
- 3.4L mileage
- I've Search & Search, Now Please Verify List?
- Wiring Diagrams Hook Up
- conversion wiring harness
- o2 Placement??
- My 87 22r to 3.4 swap
- 92 and 95 3.0 to 3.4 swap
- Parts list for the 3.4 swap
- I want to swap a 3.4 into my 22re. What do I need?
- Oil Dipstick Adapter question
- 3.4 swap driving & milage report
- Connectors?!?!?
- 3.4 pre install maintenance checklist
- Getting AC to work after the 3.4 swap
- ecm pinouts
- Really Dumb Question?????
- 3.4 Starts then Stalls????? help
- My truck had a heart transplant
- 3.4 Swap Help!!
- Wanted: 3.4
- 3.4 clutch to 3.0 flywheel?
- few questions about 3.4 swap
- donor is 4x2 goin in 4x4
- 2000 4runner Air Box question
- 3.4L swap headers
- integrity of 3.4 donor engine
- Fuel line and fuel return hose question
- 3.4 mileage How high without a rebuild?
- Manual vs Auto
- Yet another 3.4 Swap...trying to complete under $2K
- Reusable? items from 3.0 to 3.4?
- Mystery wires. Help please.
- 3.0 to 3.4 swap; Transmission questions... maybe more?
- Give me some swap suggestions!
- oil pan question
- Engine Swap & CAL smog?
- Evap canister Necassary?
- Igniter or Not?
- theft deterrent issue!!!!
- 3.0 to 3.4 cat?
- 3.4L swap thread
- How hard to swap a 3.4?
- Build your own 3.4 crossover pipe
- 95 4wd 3.0 5spd ifs to 3.4 starting this weekend
- 5vz or 1uz?
- 3.4 swap into 1995 4-Runner RWD
- 3.4l engine on e-bay
- Tofers 3.4 swap buildup
- Some 3.4 swap questions
- 3.4 Swap Done - 94 4runner/96 Taco 3.4 2wd
- what brand of oil?
- All 3.4's have a hole for a pilot bearing.
- May have found my donor truck.... 5sp/auto question
- Ecu
