misfire
Old Dec 13, 2008 | 06:20 PM
cartune777's Avatar
misfire
when i drive the truck for awhile it seems like its misfireing, would a bad or non adjusted tps cause this?
Old Dec 15, 2008 | 06:12 AM
cartune777's Avatar
anyone?
Old Dec 15, 2008 | 06:22 AM
scuba's Avatar
Yes, But so cany many other sensors and electrical components on the truck.
Check your grounds in your engine bay first..
Then pull codes..
Old Dec 15, 2008 | 11:18 AM
cartune777's Avatar
yeah i double checked me tps sensor it wasnt tight, i still need to adjust it, and ill have to get the obd plug hooked up, then pull the codes and check the grounds
Old Jan 5, 2009 | 09:42 AM
cartune777's Avatar
still doing it, this is what happens, i start the truck, runs fine drive to the gas station turn it off, get a beverage hop back in start it up MISS runs like crap, start driving home a few miles done the road it clears up. this happens when i turn it off and restart it any sugestions?
Old Jan 7, 2009 | 03:04 PM
cartune777's Avatar
had the truck scaned today, cylinder 6 misfire. thats all the codes. does any one know how many ohms the coil, injector, and spark plug wire are suppose to be?
Old Jan 8, 2009 | 11:40 AM
cartune777's Avatar
f@*king injector
Old Jan 9, 2009 | 05:28 AM
cartune777's Avatar
for anyone that has a misfire i suggest checking the injectors, my number 6 injectors was bad/clogged, i took it out ran cleaner through it and blew it out with compressed air backwards and forward while cycling it on and off with a switch hooked to power. so far truck runs great
Old Jan 9, 2009 | 05:47 AM
nv4runner's Avatar
Looks like you don't need it anymore, but the injector resistance should be 13.8 Ohms and the spark plug wires should not be above 25 K Ohms per cord according to Alldatapro.com for a 5vz-fe.
Forgot about the ignition coils...
Primary Coil
Cold: 0.67-1.05 Ohms
Hot: 0.85-1.23 Ohms
Secondary Coil
Cold: 9.3-16.0 K Ohms
Hot: 11.7-18.8 K Ohms
Old Jan 10, 2009 | 06:57 AM
cartune777's Avatar
thanks man good to know for future referance
shooter86314
Jan 7, 2016 07:05 AM
Firefightersink15
Nov 23, 2015 10:32 PM
calderp
Nov 16, 2015 02:49 AM
the_supernerd
Oct 1, 2015 09:20 PM
larrys93pickup
Sep 17, 2015 07:05 PM
