22r to 3.4l motor mounts
Old Jan 20, 2009 | 07:11 AM
VEDAVOO's Avatar
Now that ors went out of bizz, i need to get a set of motor mounts to get my 3.4l in to my 84 runner replacing my 22r. The set that ors sold the will work,not the fancy poly bushing ones just the weld on frame design $75 set. I need to find a set that maybe somebody has laying around or does any one know the measurments of them so in can build my own, i tried to e-mail them to see if i could still get a set but no response
Old Jan 20, 2009 | 12:14 PM
jasond's Avatar
Just move the 22r ones further back, I am almost certain they are at the same angle.
Old Jan 20, 2009 | 12:18 PM
ozziesironmanoffroad's Avatar
either that or check out downeyoffroad.
Old Jan 20, 2009 | 02:00 PM
VEDAVOO's Avatar
Already cut off the old ones and trashed em ,had plans to buy the set from ors. Not sure if a set from downeys will work. Need other ideas if you guys know any.
Old Jan 20, 2009 | 03:33 PM
cadman's Avatar
You might find somebody at ttora to make a set for you, or point you in the right direction at least. Quite a few of the members over there do extensive fab work and a number of them run their own shops.
Old Jan 20, 2009 | 03:57 PM
jasond's Avatar
Just make them yourself, two pieces of tube and some flat plates with holes drilled in them.
Old Jan 31, 2009 | 06:21 AM
mrdoug's Avatar
I picked up those 'fancy poly bushing' ones... doesn't sound like what you're looking for, but if you need some measurements from them, I can help with that.
Old Jan 31, 2009 | 08:48 AM
mt_goat's Avatar
Jason you always have the best ideas
Old Feb 2, 2009 | 12:59 PM
syber_kowboy's Avatar
Don't forget the little chains in case your welds break!
cars-guy
Aug 16, 2020 06:59 AM
keithporter83
Jul 24, 2015 07:37 AM
1996Taco
Jul 20, 2015 12:02 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
cars-guy
Jul 11, 2015 07:51 PM
