Starting 3.4 Swap - Some Questions
Old Oct 22, 2008 | 09:27 PM
91yota3.4's Avatar
Well I grabbed a 91 ext cab 5 speed with a blown 3.0. The truck is in nice shape, no rust on box, lil hole on fender/rocker, and it's on 32 MT's with 70%. Paid $1500CAD, which is a decent price here in Vancouver Island.
Got the motor out yesterday. The guy hydro-locked it. I'll need a new 3.0 baffle cause two rods shot a couple of nice holes in it.
I'll be using the stock cross over and hacking it up to dump on the driver side.
I also purchased all the stock AC components out of an 94, which is R-134a, for $250. I will be installing that as well and hopefully getting it to work on the 3.4 block. Might have to source out a 3.4 AC bracket.. gotta read over all that again.
Anyways, I have a couple questions I need help with ASAP.
The motor I'm looking at buying is a 99 5 speed ,it has 90,000 KM's on it. $800 with harness, no ECU, no flywheel/clutch but otherwise fully dressed. I read on Pirate that I can use either the 3.0, or the 3.4 flywheel/clutch as long as you use the 3.0 throw out bearing. Is this true or do I need to source out a 3.4 flywheel? I've read on here to use the 3.4 stuff. Either way I'll definately take this motor because I don't want to pass on the low km's at such a good price, even if I have to buy a flywheel.
And secondly. where on the 5vzfe is the VIN located?
Thanks,
Old Oct 23, 2008 | 05:56 AM
cadman's Avatar
Can't help with the clutch question since I'm auto, but there is no VIN on the engine. Instead, there is a serial number stamped on the block. It's on a flat boss located on the front left side or front right of the block just below the head. I don't remember which side but I do have pics at home if needed. I made a tracing of mine in case the referee here needed to see it.
Old Oct 23, 2008 | 10:26 AM
RobD's Avatar
You'll need to source a 3.4 clutch and flywheel. Use the 3.0 throwout bearing.
As for the VIN, someone mentioned that it's under the timing belt cover, though I can neither confirm nor deny this.
Old Oct 24, 2008 | 11:49 AM
cartune777's Avatar
im using the 3.0 flywheel, clutch, pilot bearing, and throwout bearing with a 3.4 starter, not sure if you priced the 3.4 stuff but its outrageous. also i used the stock 3.4 oil baffle, 3.0 pan and dipstick
Old Oct 25, 2008 | 09:11 PM
91yota3.4's Avatar
Thanks Cartune, I read similar info on Pirate. It's good to know I can use both.
Old Oct 25, 2008 | 09:21 PM
RobD's Avatar
My understanding is that you'll need the 3.4 flywheel and clutch because of the higher power output. Mine came with it, so I decided to run with it. I did have to use the oil pickup from the 3.0 with one of the legs cut off (you'll see what I mean, if you haven't pulled the pan yet).
Old Oct 26, 2008 | 07:27 AM
cartune777's Avatar
yeah im not trying to steer you in the wrong direction, but that set up is what im using, although everything bolts up fine, i still haven't tested it yet, ill let you know if it slips at all when i get it running
Old Oct 26, 2008 | 09:50 AM
91yota3.4's Avatar
Oh so you're not up and running yet?
How long till you're on the road?
Old Oct 26, 2008 | 12:35 PM
cartune777's Avatar
good question, hopefully in a week, im waiting for my ecu to get here
Old Oct 29, 2008 | 05:40 AM
91yota3.4's Avatar
What did you guys run for exhaust?
I'd leaning towards cutting up the stock crossover to dump to the other side, for cost reasons, but I'm worried about exhaust flow.
Old Oct 29, 2008 | 05:48 AM
Dan.3's Avatar
I dont have an auto but is the 3.0 and 3.4 clutch and flywheel the same part number?
Old Oct 29, 2008 | 06:04 AM
trbizwiz's Avatar
Ebay has cheap headers for like $225 for the 3.4. I wish they had them for the 3.slow
Old Oct 29, 2008 | 06:29 AM
RobD's Avatar
I tried doing the cut crossover route, but the 3.4 that I had dumped into two outlets at the flange. The flange was then too wide to fit between my firewall and frame rail, so I had to pull it out and have a new crossover built to dump into one outlet at the collector. Keep it tight to the block and bellhousing and you shouldn't have clearance issues.
I had a custom exhaust built from that point, since mine was crap and rusting out anyhow. You'll need two O2 sensors, or at least do the #2 O2 sensor bypass. I think Elvota has some info in his post about that.
The pipe is 2.25" back to a high flow cat, then into a high flow muffler. Anything bigger is a waste of money. It sounds good, puts out really good power and if headers would make any difference, I'm not sure I see how.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
94whiterunner
Sep 22, 2015 07:25 PM
Edionne13
Jun 21, 2015 11:37 PM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
