It's ALIVE!
Old Jul 14, 2008 | 07:36 PM
Hophead's Avatar
It's ALIVE!
As of 8:30 pm it starts! Runs like a bag of poo mind you, but it started up first turn of the key! Huge thanks to Screamer76 and HRDTED for your help - I literally could not have figured it out without your input. Props to Yotatech for inspiring me to attempt this. I am now going to pull some codes and find out why she runs so rough.
Old Jul 14, 2008 | 08:08 PM
Hophead's Avatar
How do I pull DTC's? Do I need an OBDII communication port and reader or can I just jump pins in the Diagnostic port in the engine bay and watch the CEL flash? My brain hurts.
Old Jul 14, 2008 | 08:29 PM
ozziesironmanoffroad's Avatar
is it obd2?
Old Jul 14, 2008 | 08:46 PM
screamer76's Avatar
congratulations!
any engine manufactured in or after 96 is obd2 compliant.
yes, you need to have the obd2 port hooked up to read the codes.
good luck. i hope it isn't anything too serious or hard to figure out.
Old Jul 18, 2008 | 04:08 PM
Hophead's Avatar
I thought I would post this here, not start a new thread... with work being so busy I haven't had alot of time to check things out but... It will start every time but runs very rough. I have looked over (and over) my wire connections and I am pretty confident. The funny thing I noticed today when I got home and dove into things is it will start with the MAF disconnected and actually run rather smooth? Does this tell me anything? I would assume the computer is ignoring all sensor inputs at this time and is running off set parameters. I haven't had a chance to get to a wrecker and get a OBD port so I can't pull codes yet, maybe tomorrow. If it helps I did a leak down test on the motor before installation and everything checked out good.
Anyone? Buller?
Redeth005
Jun 28, 2018 08:16 PM
4RunnerKid
Dec 7, 2004 01:45 PM
