ECU looking for a security device
Old Apr 13, 2009 | 05:52 PM
Mike Richards's Avatar
Hello out there,
I've put a 2000 4Runner engine into my 1988 4Runner. The engine will run for 15 to 20 seconds and then shuts down. the fault code is P1300. There seems to be a problem with the ECU looking for a security device which of course I don't have. Does anyone know how to disable the ECU looking for a security system? I'm at a total loss.
Last edited by waskillywabbit; Apr 13, 2009 at 06:11 PM. Reason: Title clarity per posted sticky moved to 3.4 swaps
Old Apr 13, 2009 | 06:38 PM
Elton's Avatar
could it be the chip in the key which you dont have?
Old Apr 13, 2009 | 06:55 PM
TMZ's Avatar
TMZ
P1300 code is a ignitor circuit malfunction. The vehicle would not start at all if it was the immobilizer.
Old Apr 14, 2009 | 12:58 PM
2000 4Runner
Thanks for the replies. When you cross referance the P1300 code over to Toyota it says that it is a security problem. The question I need answered is if anyone knows how reprogram the ECU or knows of a way to make it think the security system is engaged. Thanks Mike
Old Apr 14, 2009 | 04:16 PM
TMZ's Avatar
TMZ
Straight from TIS.
P1300 ignitor circuit malfunction.
Condition (a) is repeated 3 times consecutively during 6 consecutively
IGT signals while engine is running (a) IGF signal is
not input to ECM for 2 or more ignitions
Ignition system
Open or short in IGF and IGT circuits from igniter to ECM
Igniter
Ignition coil
ECM
Immobilizer codes start with B (B2796) for instance.
Williamemslie
14
Oct 5, 2015 09:28 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
bradahman
Oct 1, 2015 09:24 AM
Rcbc92
Sep 26, 2015 03:00 PM
Boomer8404
Sep 24, 2015 01:12 PM
