another 3.4 write up
Old Sep 27, 2008 | 10:08 AM
cartune777's Avatar
starting my 3.4 swap soon, if anyones interested, ill give all the info that i had questions on and how i did it,also the cost.
so far i have a 3.4 out of a 96 tacoma 70,000 miles it came with EVERYTHING $400.00
91 toyota sr5 with bad motor $300.00
ive set out to only spend $1,500 on the whole thing deal are out there ill keep you posted.
Old Sep 27, 2008 | 10:22 AM
Corey's Avatar
Co-Founder/Administrator
Go for it.
All are interested, and it is nice to see different ways how it is down.
Old Sep 27, 2008 | 10:23 AM
Fink's Avatar
Wow! $400 for the entire motor - that's a steal.
Good luck.
Originally Posted by Corey
Go for it.
Yeah, we can't have too many swap write-ups going.
Everybody does something differently and comes up with new ways of doing things.
Wrench on!
Fink
Old Sep 27, 2008 | 10:59 AM
cartune777's Avatar
ya i got the motor that cheep cause here in central Michigan toyotas are mostly considered jap crap and no one wants them
Old Sep 28, 2008 | 04:07 PM
cartune777's Avatar
well today i started switching everything over off the old motor, like oil pan sump, motor mounts, fan, oil sending unit, and i reused the 3.0 dip stick and tube i just made a new bracket to bolt it on the motor it fits snugly behind the alt. and used the existing plug to plug the front tube hole. next is the exhaust, has any one used the factory 3.4 crossover in its stock position?
Old Sep 28, 2008 | 04:36 PM
fillsrunner4's Avatar
Not another 3.4 swap
Of course we all want to see it!
But it helps to have pics along with the decriptions for us visual learners
Good luck!
Old Sep 28, 2008 | 04:58 PM
Elvota's Avatar
Has any one used the factory 3.4 crossover in its stock position?
Some have modded the stock 3.4 crossover for a DS drop.
Good writeup here:
https://www.yotatech.com/forums/f160...r-pipe-138902/
I think most go DS because of the front driveshaft and general transfer case clearance issues on a 4x4.
Old Sep 29, 2008 | 09:31 AM
G-off's Avatar
I used the stock 3.4 crossover without any mods to it, however it won't work if you have 4wd. I had to cut the diff mount off for it to clear. It would also hit the torsion bar socket if I had that still as well.
Old Sep 29, 2008 | 10:09 AM
RobD's Avatar
I tried to have the 3.4 crossover modded to work, but the double flange wouldn't clear the frame rail and firewall. So I had it built to dump down into one flange. Fit perfectly. Just have to make sure it's tight to the back of the block and close to the bellhousing.
Old Oct 2, 2008 | 07:21 AM
cartune777's Avatar
so ive hit a snag, swap is on hold, my motor is a 96 3.4 out of an auto, my plan was to use the auto harness and put the 3.0 5 speed with a 96 manual ecu, but im told i cant do that cause the plugs dont match up, my other option was to used the auto ecu that i have but cant do that either cause of fuel maps, so i think in gonna have to get a auto trans and ecu but which one? im waiting for una at ors to get back with me with parts i can use.
Old Oct 2, 2008 | 08:06 AM
Elvota's Avatar
In theory, you should be able to use the '96 manual ECU.
Do you have the plugs for the '96 ECU? If so, you have to look at the EWD for your motor and just figure out which wire needs to go where on the '96 ECU. You'll loose the auto tranny part of the wiring harness but you don't need it.
I know there are some online sources for the plugs as well if you need to get some for the '96 ECU.
Old Oct 2, 2008 | 09:50 AM
cartune777's Avatar
hmm do you know if the 3.0 plugs will work on a 96 manual ecu, if not where could i get them?
Old Oct 2, 2008 | 10:04 AM
mt_goat's Avatar
I doubt the 3.0 plugs will fit, let alone work. Search though all of the posts by "Jasond" he had some part numbers for plugs that I saw somewhere.
EDIT: Here it is: https://www.yotatech.com/50633100-post10.html
Old Oct 3, 2008 | 05:08 AM
Dan.3's Avatar
i thought I saw it on here but maybe it was on pirate. It should be possible to use the auto ecu and harness with a 5sp. You just have to fool the ecu into thinking it is in neutral. The plugs to the engine should be the exact same except that you just dont use the trans part of the auto cause wont need it.
Old Oct 3, 2008 | 06:08 AM
cartune777's Avatar
thats what i was thinking also, but if the computer thought it was in neutral the hole time wouldnt the fuel maps and timing curve be off? on in auto ecu does putting it in gear cycle closed loop?
Old Oct 3, 2008 | 06:24 AM
mt_goat's Avatar
... on in auto ecu does putting it in gear cycle closed loop?
Interesting question, not that I've ever noticed, but mine usually goes into closed loop pretty quick after startup. Next time I have my laptop in the truck I'll take a note of that.
EDIT: Now I have noticed a pretty sharp change in A/F when I step on the brake or release the brake, but I thought that had something to do with the change in vac pressure from the brake booster. You got me thinking now.
Old Oct 3, 2008 | 06:48 AM
cartune777's Avatar
mr goat that would be awesome if you could check that out, so many variables
Old Oct 3, 2008 | 07:30 AM
mt_goat's Avatar
If it were me, (and it was at one time hehe), I'd try to find an ECU that goes with the engine and engine harness. Maybe you have I don't know. But yes, I'll try to remember to check that out.
Old Oct 5, 2008 | 06:01 AM
cartune777's Avatar
i figured out what im gonna do, i found a 96 manual harness, and 96 manual ecu so im gonna get them just to make things easier. im in the middle of building the crossover pipe thanks to jason4x4's thread good stuff ill post some pics.
Old Oct 5, 2008 | 12:34 PM
screamer76's Avatar
make sure that crossover to downpipe flange sits as close to the bellhousing as possible. not a whole lot of room to play with there
